01 S4 boost?
Old Apr 15, 2006 | 03:24 PM
kup125's Avatar
Default 01 S4 boost?
i was wondering if anyone knows the stock boost setting? and what is a safe amount you can turn it up on a stock setup?
Old Apr 15, 2006 | 04:14 PM
sooks's Avatar
Default RE: 01 S4 boost?
Im not positive..but i believe its 8 psi
Old Apr 16, 2006 | 09:55 PM
NavyS4guru's Avatar
I could be wrong but i believe it peaks and then tapers... but i wouldnt know the numbers.
Old Apr 17, 2006 | 09:13 PM
kup125's Avatar
come on, someone must know something
Old Apr 17, 2006 | 09:18 PM
scarzie's Avatar
should spike to about 10, and taper at around 8 or so if im not mistaken
Old Apr 17, 2006 | 09:19 PM
scarzie's Avatar
GIAC spikes that up to topping out at either 18 or 10, and tapering off to 16, or 18 if it spikes to 20
Old Apr 18, 2006 | 09:51 AM
AudiFast's Avatar
Hey guys,i just installed my boost gauge and right now it stays at like 20 below the zero.What should it be reading?do i have a boost leak?When im speeding up it spikes to 5, but thats it.help please...
Old Apr 18, 2006 | 12:19 PM
Roadhawk's Avatar
Audifast - it sounds as if you are in what is called "Limp Mode" which is due to your ECU detecting some significant problem - boost leak or something else related to your engine/turbo performance. You need to get it thoroughly checked out and dealt with. Its telling you that if you were running with boost you would be damaging something....
Old Apr 18, 2006 | 12:25 PM
AudiFast's Avatar
how much are we talking...and what do i go to a tech and say..im in limp mode?
Old Apr 18, 2006 | 02:30 PM
AudiFast's Avatar
Roadhawk...anybody?
