2003 s4 engine specs
Hey there guys 'n' gals.
I am building up a race car using the BBK 4.2 V8, but I am struggling to find a full tech spec on it. if anybody can help I will be so greatful.
I need:
how the variable cam timing works, what the changes areand at what rpm,
When the variable inlet manifold cuts in
A rating on all the fuses for the car.
Any other specs for the engine would be fantastic
Oh and any serious tuners for that engine???
Cheers all ~Pee
I need:
Cheers all ~Pee
I wasn't being sarcey
I was merely pointing out how difficult your question was,I believe the answer could only be achieved through rolling road tests or data logging with VAG.
VCVT is very complicated but as you probably know that already
I was merely pointing out how difficult your question was,I believe the answer could only be achieved through rolling road tests or data logging with VAG.VCVT is very complicated but as you probably know that already
No boys I'm on about the BBK engine (4.2 V8) not the V6 Turbo. So dwcs4 you can give me the specs or don't you have them????
Just because I am new it doesn't mean you have to look down your noses at me.
The S44.2 with the BBKwas made in 2003 because I have them in my workshops.
Just to give you guys an idea we are building a gt car with this engine weighing 800kg or 1760 lbs with alot of carbon, titanium and inconel.
Any help would be with the specs will be fantastic...
Cheers Pee
Cheers Pee
