My 2004 B6 S4 Sedan
I bought this S4 from a guy in San Antonio with about 67,000 miles on it. It came with a new clutch and flywheel (nothing special, just replacements). Interior leather and electronics were all in stellar shape. I am the third owner of the vehicle and it seems as though all maintenance has been recorded.
As of right now, I have logged a few thousand miles and taken it to the “stealership” a couple of times. Had the transmission flushed, and an inspection done (which they do anyway) to find issues. They found a decent oil leak and upper control arm bushings that were almost nonexistent. I also found out that some starting issues came down to a problem with my engine wiring harness – the grounds were corroded. I have since changed the oil myself and replaced all tires. The purpose of this thread will be to log and update plans, upgrades, and maintenance as they are attempted and or completed. Feedback is appreciated and questions are encouraged. January 2008 - 50,100 Battery replaced July 2008 – 59,000 Oil change Mobil 1 0w-40 Spark plugs Fuel filter Air filter Cleaned throttle body August 2008 – 60,000 DBA rotors Carbontech brake pads Motul 6000 brake fluid Motul 6000 clutch fluid July 2009 – 65,000 Serpentine belt replaced (alternator) Lightweight crank pulley Snub mount 10mm Air intake spacers Valve cover gaskets replaced (leaking) Temp sensor replaced Clutch pedal switch replaced Driver’s front window regulator replaced September 2009 – 66,000 Oil change Mobil 1 0w-40 Cabin pollen filter November 2009 – 69,000 VMR V710 wheels and Toyo Proxes 1 tires Hotchkis sway bars Apikol rear differential mount May 2010 – 74,200 Oil change Mobil 1 0w-40 Transmission fluid flush w/ Redline MT-90 Rotated tires June 2010 – 74,800 NGK Spark plugs “T” Version coil packs installed Purchased Vehicle June 2012 – 90,081 Oil change Mobil 1 0w-40 Coil packs replaced (dealer recall) July 2012 – 90,147 New tires 245/35R-19 Bridgestone Potenza S-04 Pole Position XL Flushed transmission (dealer) August – 91,105 K&N Air Filter http://farm9.staticflickr.com/8424/7...bac22429_b.jpg http://farm7.staticflickr.com/6031/7...fb7cf882_b.jpg http://farm8.staticflickr.com/7275/7...dbe25dff_b.jpg |
Next planned service:
- (Repair) Engine wiring harness (when it comes in from Germany) - (Repair) Oil leak fixes - Intake gaskets, Valve cover gaskets, Cam pos. sensor seals, Oil filter housing gasket - (Repair) Upper control arm bushings - 95,000 mile maintenance - Oil change, Dust/Pollen filter, Alignment Planned mods: - Headlights (painted with CCFL's) - New H1S 6000k HID bulbs - Powder coated wheels (color to be decided) - Powder coated calipers (color to be decided) - Powder coated valve covers and possibly intake manifold (wrinkled red) - Full exhaust (Milltek, APR, AWE, or Billy Boat) - Tune - H&R Springs - Interior LED's |
H1S 6000k HID bulbs installed, LED taillights installed, and intake spacers on order.
http://farm9.staticflickr.com/8307/7...3bd69bf3_c.jpg http://farm9.staticflickr.com/8042/7...1ccdbdcb_c.jpg http://farm9.staticflickr.com/8436/7...2e4880b6_c.jpg http://farm9.staticflickr.com/8435/7...251b9d16_c.jpg |
Rear Lighting
What kind of bulbs are you using for the license plate lighting?
Originally Posted by palendromer
(Post 1405548)
