Air intake
Old Mar 29, 2007 | 08:26 PM
myaudi98's Avatar
Default Air intake
So i wanted to know what you guys think of a air intake for the 2.7 motor. I got one from AWE tuning and wanted to know if it will fark anything up with my car. Any thoughts?
Old Mar 29, 2007 | 08:44 PM
skunkoncrunk's Avatar
Default RE: Air intake
It shouldn't. Besides, isn't all there stuff mean't for Audi's?
Old Mar 29, 2007 | 09:01 PM
myaudi98's Avatar
yeah, just didnt know if anyone had experience with it before.
Old Mar 29, 2007 | 10:15 PM
2k S4's Avatar
What did you get? The S-flow? Yes it fine, but don't except much from it.
Old Apr 2, 2007 | 04:54 PM
BITRBO's Avatar
I read a bunch of threads on this subject (here, AZ andS4biturbo.com),andthe consensus was that the Darintake flowssignificantly better than the S-Flow(for a lot less $$$). I would assume the primary reason for this is because of the holes that are cut in the bottom of the stock air-box to provide an additional and cooler air supply into the system. That being said, it would stand to reason that the S-Flow could potentially produce the same gains (if not better) if an additional cold-air supply was introduced, similar to what the Darintake utilizes (the holes). Considering we're fairly restricted on how largeof pipe and filter you can fit inthe stock air-box, it just becomes a question of which one has the better filter type and tubular flowefficiency (component design).
I would bet an S-Flow with the Darintake holes would actually yield some noticable gains, than an S-Flow without the holes...
p.s. If this conclusion and/or discussion has already been drawn, please disregard my ignorance
Old Apr 2, 2007 | 05:31 PM
mattr7786's Avatar
ORIGINAL: ZQ8GMC
[sm=icon_cheers.gif]
[sm=exactly.gif]
Old Apr 2, 2007 | 06:14 PM
onefasts4's Avatar
s-flow is probably the best until you get to stage 2+. The s-flow has been known to collapse at high boost. I have an s-flow and its great. The only downside is that the filter needs periodic oiling and cleaning.
Old Apr 2, 2007 | 07:05 PM
2k S4's Avatar
ORIGINAL: ZQ8GMC
BRILLIANT! Welcome to 4years ago....
LOL, I kid.
Old Apr 3, 2007 | 12:10 AM
BITRBO's Avatar
guess I missed that thread...
ORIGINAL: onefasts4
Well, that's prettygood to know before spending 180 beans on the damn thing. I'd almost opt for the Darintake then using a standard K&N cone/cylinder-shaped filter, but I digress again: The oil in the K&N's tend to mess with the MAF, don't they...? You just can't win![:@]
Old Apr 3, 2007 | 02:00 AM
2k S4's Avatar
ORIGINAL: ZQ8GMC
Yea, K&N not so good on the MAF. Some guys have gone with the new AEM Dryflow filter. Even an ITG panel filter will be better with the darintake. I have one, that I tested back to back with the S-flow & my logs only showed around 10g/s in the very upper RPM's from the panel to the S-flow. This tells me the stock airbox flows very well.
