Airbox Reinstall Help!
Old Mar 29, 2007 | 08:04 PM
OrientExpress01's Avatar
Default Airbox Reinstall Help!
Hey guys,
I just replaced the intake filter with a K&N and everything's pretty much gone smoothly (entire thing too less than 15 minutes), EXCEPT I can't get the last clip back onto the airbox. The clip is located in the rear (back right corner) and there is very litte wriggle room there for my fingers. I tried using a really long screwdriver to work it into place but I couldn't get enough leverage (spent over an hr trying to work it too...so I've definitely tried). Has anybody who replaced their filter run into this problem? How were you able to get it back in place? and lastly, does it matter if this clip is not on? It seems like the entire thing is pretty much airtight now.
Sometimes I wonder how mechanics can work in such a tight engine bay. It makes even the simplist of tasks nearly impossible (like clamping one clip!)
Old Mar 29, 2007 | 10:18 PM
2k S4's Avatar
Default RE: Airbox Reinstall Help!
I would not run a K&N, the reason is, the oil in the filter can mess up the MAF.
The best way to get it all back in, is to remove the entire airbox, put in the filter, then replace the whole thing as a unit.
Old Mar 29, 2007 | 10:24 PM
Superdug's Avatar
SoCal Crew Member/White Devil
what should we do to get more air? should we just drill the air box to suck more? or go to a cone filter?
Old Mar 29, 2007 | 10:34 PM
2k S4's Avatar
ORIGINAL: Superdug
There are a ton of other filters out there. ITG makes a replacement panel filter. AWE also makes a cone filter then goes in the stock airbox.
Really on a stock car, the filter will not really do anything. While cutting holes in the bottom of the airbox does help, again, don't expect anything with a stock car.
The airbox is not the restriction, the exhaust & DP's are.
Old Mar 29, 2007 | 10:40 PM
Yea, I'm really doing this to replace to stock filter, which had been in there for 46k miles. I never heard of the oil messing up the MAF on the S4 (although I have heard of problems with MAF and the K&N oil with my old SE-R Spec V).
It seems to be a rarity though since quite a few people seem to use K&N as replacement filters w/o much problems. I did a search on the forum on K&N and did not find posting with problems. If you could provide some links, I would like to read about it. Thanks!
Old Mar 29, 2007 | 10:46 PM
Ok, I did a search on MAF and found a thread on it. It seemed rather debatable, with some people saying its not a problem, and others saying it causes problems. I'm pretty much confused right now, but I do have a Hitachi MAF and I never had problem w/ the K&N oil in my last car.
Old Mar 30, 2007 | 06:11 PM
Hano's Avatar
you don't necessarily need that last clip in for the airbox fyi
Son-of-spitfire
Audi Q3
Jul 10, 2015 08:36 AM
hardiek
Dec 17, 2012 09:22 AM
Chico Suave
B8 Models
Feb 4, 2012 08:02 AM
cmotley
Aug 24, 2010 12:07 AM
vtraudt
Feb 8, 2010 01:55 PM
