Alignment questions? kinda dummm
Old Jun 23, 2007 | 05:26 PM
TKneedsS4's Avatar
Default Alignment questions? kinda dummm
Alright soo i bought new tires a few months ago on spring break. Drove about 500 miles on them then had the suspension done (koni coilovers). The shop told me they did a alignment so i wasnt to worried about it. But after alot of town driving (35-45 mph) and finially getting on a highway. i realized that something wasnt right. So i thought it was wheel bearing again but its not and narrowed it down to alighnment. so i went back to the tire center and had my alignment redone. and the guy tells me cause my car is lowered that the camber is now way off and it can be totaly aligned properly cause of the coilovers????
Has any1 had anyhti9ng luiek this?
If any1 can make sense of the computer pring out of all the alignment info.... i do have it and i oculd post it up and see what u guys think.
But all i am really asking is this a common issue with coilovers and or whats this bs they were saying about only being able to correct it with a camber kit?
And my car has a serious hop/vibration at 60mph+
Thanks for the help
-tk
Old Jun 23, 2007 | 05:30 PM
Mott Power's Avatar
Default RE: Alignment questions? kinda dummm
Camber should not be an issue with something like that, considering you have double wishbones you won't get extreme camber from lowering the car.
Old Jun 23, 2007 | 09:08 PM
2k S4's Avatar
Yea, camber will not cause this. Camber just lets you turn in a little faster, & gives better cornering grip, @ the expense of tire wear.
You will have more camber then stock, depending how low you go.
Sounds to me that the toe is off.
You can adjust that, & make sure the "cradle" is adjusted so that the camber is the same from side to side.
jants13
May 27, 2009 01:04 AM
dougalan
Apr 9, 2008 07:00 PM
neilechols
Nov 6, 2006 09:30 AM
Sydeshow MO
Sep 13, 2006 08:29 PM
chelskisw6
Oct 25, 2004 06:49 PM
