Any tech in the HOUSE? question about TSB #0402
Old Oct 18, 2007 | 11:49 AM
SchlafwagenS4's Avatar
Default Any tech in the HOUSE? question about TSB #0402
I was reading the TSB section of the forums and came across this one
https://www.audiforums.com/recalls-a...d_0402/TSB.htm
Is the fix just a replacement of the valve cover gasket.I have no visible leaks on my car, but in the last 3 weeksI have had to add about 1/4 qt ofengine oil. I don't know if this isjust regular engine burnoff, oraslow leak or something worse. some help with DX would be appreciated.
Old Oct 19, 2007 | 01:39 PM
2k S4's Avatar
Default RE: Any tech in the HOUSE? question about TSB #0402
If your VCG is leaking, it will smell from the oil hitting the turbo, or you would have a spot on the floor.
Common leaks are.....
VCG
cam adjuster seals
cam seals
lower & upper oil pan
sandwich plate
If you are loosing oil, with no visable leaks, I would remove both lower IC pipes & see if it's in there, chances are it's some blow bye, or maybe a failing turbo.
Old Oct 19, 2007 | 01:41 PM
techbod's Avatar
valve cover gasket
Old Oct 22, 2007 | 12:57 AM
Thanks skS4 and Dave for the help, now I have a few follow up questions. Concerning the changing of the VCG.
How hard is it on a scale of 1 to 10 to change the VCG?
Does it require a complete engine pull?
If I were to take it in to someone else to be changed what kind of costs should I be looking to expect?
(I don't have my bently repair manual or my operator's manual yet, they have been ordered and I am waiting for them to arrive.)
thanks for the advice guys.
Old Oct 22, 2007 | 01:04 AM
2k S4's Avatar
ORIGINAL: SchlafwagenS4
It's like a 4-8hr job depending on your skills. More time if you have a tip. You don't need to pull the motor, just most of the stuff over the valve covers. It's a pretty straight forward job.
Old Oct 22, 2007 | 09:28 AM
thx man
joelml
Sep 18, 2007 06:16 PM
khj677turbo
Jul 13, 2007 05:33 PM
Soley4pres
Jan 5, 2007 10:28 PM
badassb5
Dec 7, 2006 05:05 PM
Devilish
Dec 2, 2006 12:39 AM
