B5 S4 only pushing out .5 bar??? (7ish psi) // Aweful rattling in rear
Old Sep 21, 2009 | 08:40 PM
dnasians's Avatar
Default B5 S4 only pushing out .5 bar??? (7ish psi) // Aweful rattling in rear
Fixed
Old Sep 21, 2009 | 09:14 PM
bigern45's Avatar
1) thats right on par for what a stock s4 puts out.. 7 to 8 psi.
2) could be upper control arms, could be motor mounts.. i think more than likely your control arms..
Old Sep 23, 2009 | 11:00 AM
mys4.org's Avatar
Where is the rattling sound coming from?
Old Sep 24, 2009 | 12:35 PM
dnasians's Avatar
it sounds like it comes from underneath? (suspension possibly?)
Old Sep 24, 2009 | 08:33 PM
RED_01's Avatar
Front or rear? We can help diagnose the problem better with the more specific you are. There are several components in the suspension that could be culprit.
Old Sep 25, 2009 | 11:56 PM
dnasians's Avatar
ok well the rattling sounds like it is coming from the rear, possibly underneath the car. im not sure what it could be. i've made a short list of what it could be.
-control arms
-spring seats
-loose something?
-sway bar
anything will help, really! thanks
Old Sep 26, 2009 | 01:12 AM
RED_01's Avatar
-control arms
-spring seats
-loose something?
-sway bar
If I had to guess I would first check the control arm bushings and sway bar bushings and links.
You need to neutralize the sway bar to check the links. For example; with the car on the ground or with the wheels loaded evenly (like on ramps or a drive on rack to get under it) so that niether wheel is higher or lower than the other.
Or if you can, disconnect one side and see if either side has play.
You can check the control arm bushings by jacking under the lower arm as close to the tire as possible just enough to get the wheel of the ground. This will keep neutralize the suspension on that side enough to wiggle the wheel to check for play.
A good visual inspection never hurts either.
Let us know what you find or if it's something else.
Old Oct 3, 2009 | 10:54 AM
Emilgevor's Avatar
Off-topic
RED1 did you photoshop your bumper lol?
A4 2000
Nov 13, 2011 05:51 PM
kobe2008
Apr 23, 2008 11:29 AM
chusaiyan
Mar 26, 2008 04:05 AM
cali4life9092002
Mar 15, 2007 10:42 PM
EvilA4
Jan 8, 2005 01:30 PM
