b6 clear corners
Old Mar 29, 2008 | 10:37 AM
harris's Avatar
Default b6 clear corners
i have an '06 s4 cabriolet, b6 body. was interested in doing the clear corner mod for these headlights. problem is looks like a lot more connection points than the earlier body styles. also looks like these points (like 4)are located on the side. anyone attempt this? looks like all old posts are from the earlier models with simply the upper and lower single points. thanks in advance. harris
Old Mar 29, 2008 | 12:12 PM
audiprotein's Avatar
Default RE: b6 clear corners
06 is a B7, if u got a b6 here is a DIY http://a4mods.com/index.php?page=web...earcorner.html
Old Mar 29, 2008 | 01:29 PM
harris's Avatar
thanks saw that one too. mine is the s4 cabrilet. they are one year behind the sedan in body style. i just drilled one side out. four tabs on the side. none top or bottom. was a pain cracking up the lens though. i pulled it in front of the clear inner lens. maybe ill try and push it through the projector hole on the other side. any writups on removing the air intake on the other side? im about to do that now. thanks
harris
Old Mar 29, 2008 | 01:54 PM
bronxblaza117's Avatar
ORIGINAL: audiprotein
he has an s4 not a4...
Old Mar 29, 2008 | 02:41 PM
sean1.8t's Avatar
ORIGINAL: harris
harris
4 tabs on the side? is the S4's lights that much different than the A4's?breaking up the lense? you don't have to. did you read the write-up. my CC job took like 15 minutes a side and it was SUPER easy compared to the time i did it on my B5..
Old Mar 29, 2008 | 03:31 PM
harris's Avatar
thanks for the reply. there is like a lens inside a lens. the outer is a one piece clear, but by the markers is an inner 2 piece. all the way to the side is the yellow which is connected on the side, not top and bottom. between the yellow and the projector is translucent reflective type lens. ill try and add photos. sorry in advance if these come out big.
harris
Old Mar 29, 2008 | 03:49 PM
harris's Avatar
sorry let me try the pics again
Old Mar 29, 2008 | 03:52 PM
harris's Avatar
after removal
[IMG]local://upfiles/50526/B85F732F7F414A7D8E3D35D88041DBBB.jpg[/IMG]
Old Mar 29, 2008 | 03:54 PM
harris's Avatar
before
[IMG]local://upfiles/50526/A220E0C8B4E34DC8BE3F86C6A04F477C.jpg[/IMG]
Old Mar 29, 2008 | 05:51 PM
harris's Avatar
anybody take out both the yellow and the clear translucent pieces???
