BOOST GAGUE!
Old May 17, 2006 | 03:19 AM
Audis42001's Avatar
Default BOOST GAGUE!
http://www.taner.net/s4/boost_gauge/
i saw that boost gague on that website just wondering wheir 2 get it bec i never saw that 1 before i like the way the piller look but the pillers cloth is a bit darker. anyone have any info on this piller and gague does it work good ? any pros and cons ?
Old May 17, 2006 | 04:14 AM
redleg6's Avatar
Default RE: BOOST GAGUE!
it sounds like english; it even looks like english, but I can't understand a word you're blabbering, try learning elementary grammar before attempting to inflict your next literary abomination on this forum...
ok so i'm kidding, i just couldnt help myself, why do you need a boost gauge? do you have a boost controller installed already? i would install a gauge somewhere inconspicuous if you get one and not sticking out on the a-pillar
Old May 18, 2006 | 03:00 PM
Hano's Avatar
awe sells a boost gauge that you can install in one of the center vents. it fits perfectly and is probably the best way to go. the airbags on the a pillar make a pillar boost gauges a threat if you ever get into a car accident. if that airbag goes off, that boost gauge will be a deadly projectile that could cause some damage.
Old May 18, 2006 | 08:33 PM
scarzie's Avatar
yah it could be dangerous if you get into an accident. The vent mount guages look a lot cleaner too
Old May 18, 2006 | 09:06 PM
chebert69's Avatar
I agree with that danger part about the air bag. I have AWE center mount BG
and it look great + the install is not that bad to do with a little patience. Lightning
matches stock (red back ground, white needle). It look stock and it's a useful tool
for u to know if you get optimal performance.
BTW what is the conversion in PSI of 1.3 BAR ???
[IMG]local://upfiles/9918/9685D2D8AE6E427594410AC8868ED7EB.jpg[/IMG]
Old May 23, 2006 | 07:46 AM
brendon2k's Avatar
www.google.com + 1.3 psi to psi = "1.3 bar = 18.8549059 pounds per square inch"
One bar is about atmospheric pressure which is about 14.
TeeterTawter
Jan 20, 2013 12:14 PM
jssteinke
Oct 25, 2012 09:35 PM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
DurTTy
Aug 3, 2007 03:09 PM
onepoint8tee
Jun 27, 2007 04:38 PM
