boost gauge hesitiation
Old Jan 30, 2007 | 08:55 PM
mattr7786's Avatar
Default boost gauge hesitiation
alrite let me start by saying i got the awe steering column boost gauge and it has been installed for about a month now.and has been working excellent ...today i just noticed that when it is down in the vaccum, the needle hesitates and goes up like it almost clicks every number??? but when it gets to the lbs of boost then it doesnt do it anymore....can you please fill me in with what you may think that it is.....i was thinking maybe sticky DV's???? let me know what you guys think.....
Old Jan 31, 2007 | 01:23 AM
hyperlight900's Avatar
Default RE: boost gauge hesitiation
maybe a sticky needle and since theres alot more pressure when it oes up into the boost area it doesnt stick any more....but hey idk lol just a guess
Old Jan 31, 2007 | 03:11 PM
2k S4's Avatar
Where is the line tapped from? Doubt it's the DV's as they don't work in vacuum.
My thought is a small line leak, or even a kink in the hose. Maybe the T fitting is broken, or doesn't have the little bras fitting in the line to the gauge.
Old Jan 31, 2007 | 03:18 PM
GeilKyle2's Avatar
mine gauge from awe did the same thing after about 8 months. never figured it out though... i guess I never really got ambitious enough to do anything about it
Old Feb 1, 2007 | 03:36 AM
mattr7786's Avatar
well i never thought of the kinked hose .....but i know for a fact that the brass fitting is in the Tand that it is on the line going to the gauge......and it is tapped off of the only 3mm cloth hose ( if your looking at the motor it will be to the upper right almost in the back of the motor )....i went as close as i could to the manifold as i could go....and tightly ziptied everything !!!! but im definitely gonna check that kinked hose thing out ...
ORIGINAL: 2k S4
Old Feb 1, 2007 | 03:38 AM
mattr7786's Avatar
does it do it constantly or off and on?? and i have only had mine for about 3 months .....and AWE is sposed to =quality ...anyone else have the AWE boost gauge and this is happening to???
ORIGINAL: GeilKyle2
Old Feb 1, 2007 | 02:58 PM
2k S4's Avatar
ORIGINAL: mattr7786
Mine works perfectly, been in there for about 2 months.
Old Feb 1, 2007 | 03:07 PM
GeilKyle2's Avatar
i had the expensive center vent gauge too, wasn't real happy with it, had problems with moisture getting inside it, and then after 8 months or so it started to stick, not sure if it was moisture related could of been
Old Feb 1, 2007 | 04:19 PM
mattr7786's Avatar
mine is on the steering column and i love it ....
2ks4
I made the pic work for you
Old Feb 2, 2007 | 02:43 AM
TKneedsS4's Avatar
Matt quick question, see you got custom catback and remus muffler... what one do u have??? got any picS?
I was looking to go with 2 72d's side by side because the 70d was only single in dual out. i wanted a true dual.... thanks.
