Boost Leak? (pictures included)
Old Oct 4, 2007 | 11:17 PM
to3o's Avatar
Default Boost Leak? (pictures included)
My s4 used to push me back against the seat while accelerating on first gear (when I got the car - a month ago). I do not have a boost gauge installed yet. I have noticed that this does not happen anymore (maybe, I just got used to the way the car runs… but maybe I have a boost leak). I read in past posts that first gear does not have a lot of boost anyways… the real boost comes with the higher gears.
Today, I found this:
“There is also a good chance that your DV's are leaking under high boost. if there stock, I would just say they are leaking, & replace them with 710N DV's.” by 2k S4 https://www.audiforums.com/m_484825/tm.htm
So, I decided to check my stock DVs. There is a hose between the DVs which may be cracked (look at the images below). Can this hose be replaced with regular rubber hose?
Old Oct 5, 2007 | 12:07 AM
ChumbaWumba's Avatar
Default RE: Boost Leak? (pictures included)
its just a vaccum hose...u can replace it with a rubber hose...when i first bought mine back in june i noticed that hose in particular...replaced it with a rubber hose...not sure of the exact size...and didnt even put clamps on it cuz it fit so snug
Old Oct 5, 2007 | 03:20 PM
to3o's Avatar
Thanks ChumbaWumba. Could the boost problem be caused by this little hose?
Old Oct 5, 2007 | 10:41 PM
mattr7786's Avatar
yes it could def be the problem..go out and by some new dv's and it should come with the whole hose kit.. i know my samco dv's came with all new hoses and clamps
Old Oct 6, 2007 | 04:30 PM
Blue_S4's Avatar
i had a similar problem, obvious tear near the DV joint. Went to NAPA, got 5.5inches of 5/32 vacuum tube, and replace, its a real tight fit, so no need for clamps.
livinglegend2100
Nov 26, 2011 10:16 AM
strcruizer
Apr 16, 2009 10:15 PM
strcruizer
Mar 23, 2009 12:22 AM
skeeterxb
Jun 27, 2007 09:50 PM
A4blackedout
Apr 3, 2007 06:42 AM
