Brake Issue.
Old Mar 24, 2008 | 05:48 PM
Reiem125's Avatar
Default Brake Issue.
Okay so I had just recently replace Rotors and pads all around, everything was fine until a couple days ago. I started getting a nasty ear piercing sqeal that sounds like its coming from my driver side front. I have tried everything I can think of I regreased the slides the caliper sit on, applied adhesive to the backs of all the pads, and hard braked a few times thinking i had some crud between my pads. The wierd thing is it doesnt sqeak when its extremely hot, or when I drive it when the rotors are cold, it only squeaks right before the car comes to a stop at around 5-10MPH. If anyone has anything your replies are greatly appreciated. Thanks
Old Mar 25, 2008 | 06:05 PM
james01's Avatar
Default RE: Brake Issue.
make sure that your dust shields behind the rotors are not touching or very close.
Old Mar 25, 2008 | 09:32 PM
Reiem125's Avatar
You know I was thinking about taking them off, I wasnt sure if that would hurt at all? But i think I'm going to do that and see if the noise goes away. I also applied a s*** load of the adhesive on the back of the pads and the sound is less frequent and not as loud, but still there none the less. The pads I have on there are duralast too, anyone have any issues with them? I was thinking of going with some ceramic pads eventually anyway.
Old Mar 25, 2008 | 09:41 PM
bbueschel's Avatar
My car has the same problem man. Its so obnoxious!!!!
Old Mar 26, 2008 | 01:53 AM
drev500@aol.com's Avatar
If you do go ceramic you should replace the rotors. The ceramic pad create more heat and could warp the stock rotors.
Old Mar 26, 2008 | 10:58 PM
Blue_S4's Avatar
ok...if you dont like noise...ceramic are a good idea, but may not be the answer. there is a break in with break pads...squeaking is just little vibrations from imperfections caused by breaking on old pads...the new pads will help fill in those little imprefections, you just have to give it some time....
Old Mar 27, 2008 | 08:09 PM
Reiem125's Avatar
Well the thing is for the first 300 or so miles the pads were fine no noise, so it was just a little odd to me. Thank you all for you replies
Old Mar 1, 2011 | 12:32 PM
ColumbusAudiA4's Avatar
Anyone else have suggestions. I just bought my 2005.5 a4 and right rear is sqealing just under 10 mph whether applying brakes or not and whether clutch is in or not it sqeals. Do u think just needs the grease on the back of the pads. All was dealership maintained from previous owner. Has duralast pads on it as well.
abc27
Aug 25, 2013 04:19 PM
Larrysa4
May 28, 2012 10:54 PM
Andrew149
Sep 15, 2009 03:22 PM
Dallas09
Feb 14, 2009 05:08 PM
k5gixxer
Dec 17, 2006 11:53 AM
