brake pads worn....
Old Apr 8, 2008 | 02:33 AM
washyourrhands's Avatar
Default brake pads worn....
so they finally are
what do you guys think i should get for some new ones?
im looking for some high preformance low dust ones
and do you think itd be a good idea to get like some slotted rotors too?
just need some oher peoples opinions thanks=]
Old Apr 8, 2008 | 09:25 AM
CamoA6's Avatar
Default RE: brake pads worn....
ECS has good options for the B5 S4. check them out. they have tons of pads and many different rottors.
Old Apr 8, 2008 | 12:23 PM
should i get some ceramic ones?
and what rotor is best?
im so clueless when it comes to brakes
Old Apr 8, 2008 | 12:58 PM
Blue_S4's Avatar
ceramic wont create dust...i will be getting those soon, and have some brand new upgraded pads from VAST available...
Old Apr 8, 2008 | 04:27 PM
audi ops's Avatar
don't ceramics eat rotors, not that that matters, just wondering...
Old Apr 8, 2008 | 07:36 PM
well i think ill get ceramics then
should i get slotted rotors too or should i just stick with stock for now?
Old Apr 8, 2008 | 09:58 PM
drev500@aol.com's Avatar
get some slotted and or drilled rotors. Ceramic pads create a lot more heat then stock pads and there is a chance of the stock rotors warping. Anyways drilled and slotted rotors look sick.
Old Apr 8, 2008 | 10:22 PM
Blue_S4's Avatar
ceramic pads to tend to warp stock discs faster than normal pads because they have a greater friction ratio, stop better. the pads themselves withstand heat better however.
Slotted rotors will help a ton, as would cross-drilled. the 2 together may look cool, buts its basically pointless.
good----drilled = street use
better-----slotted = Track use
sometimes best-----drilled and slotted = pointless on a street car...and if the disc is cheap, it may be weaker
Old Apr 9, 2008 | 09:43 AM
SourDieselS4's Avatar
I have DBA slotted rotors in the front and back with Mintex red box pads, they are not really agressive but better than stock, long lasting, and low dust. They also have the sensor cables so youdont have to short them out.
I like slotted or dimpled (like Stasis) rotors more than anything drilled.
Ceramic sounds sick
Old Apr 9, 2008 | 02:56 PM
so what i ended up doing was buying slotted and drilled rotors and ceramic brake pads from ECS tuning
should be better
im stoked and my twin 1 exhaust is on its way=]
