CEL Codes P1411 and P1423
Old Jul 7, 2008 | 06:52 AM
bolob5's Avatar
Default CEL Codes P1411 and P1423
So I threw these two codes on the way to work today and I am trying to figure out what they are for??? I recently replaced the two pre-cat o2 sensors but these are coming up as emissions related also. Any help would be much appreciated. Thanks.
Old Jul 7, 2008 | 07:48 AM
techbod's Avatar
Default RE: CEL Codes P1411 and P1423
bank 1 and 2 air injection low pressure detected check for pipe off or split
P1411 = bank 2 leak detected
P1423 = bank 1 leak detected
Old Jul 7, 2008 | 12:26 PM
bolob5's Avatar
Any area in particular? Boost leak????? I'm trying to trouble shoot on it this tonight...
Old Jul 7, 2008 | 01:07 PM
techbod's Avatar
Old Jul 7, 2008 | 01:22 PM
bolob5's Avatar
So like a billion different areas could be the problem... GREAT!!!!!
Old Jul 7, 2008 | 02:35 PM
techbod's Avatar
the link is there to show you what your looking at not to point out other problems ( your looking for a leak in one of the pipes )
Old Jul 9, 2008 | 06:53 AM
bolob5's Avatar
Well I can't source the leak... I thought I had it but I threw the same codes again on the way into work. Bank 1 and bank 2 are specific to what areas of the block? I really need to get a repair manual...
^Thanks for the help techbod and the sarcasm wasn't directed at you just my car luck his month...
Old Jul 9, 2008 | 08:42 PM
geoff's Avatar
check the t fitting that connects the two secondary air combination valves to the secondary air solenoid. There's a recall on the 2.7 L allroads for that fitting breaking. Take the intake Y pipe off the top of the engine, unplug the pipe for the brake booster and the crankcase breather at the back of the intake manifold. Follow the two vacuum lines coming off of the combi valves to the t fitting and make sure it is still in one piece. If not that make sure your sec air pump is working, check that the combi valves are getting a vacuum supply when the pump is running, and check for carbon build up in the plastic hoses coming off the combi valves. sorry if this isn't to helpful, it's either to fix it than to describe how to fix it sometimes. good luck
Old Jul 10, 2008 | 01:03 PM
bolob5's Avatar
^bump
- I will try that this weekend. Thanks for the help
d00dbr0
Jun 26, 2011 02:50 PM
audiLOVESwisco
Feb 19, 2011 12:11 PM
kbunting
Sep 5, 2010 04:19 PM
mikehh
Jan 25, 2009 01:24 PM
james0013
Sep 26, 2008 03:04 PM
