check for boost leak?
Old Aug 14, 2007 | 08:16 PM
huviduc's Avatar
Default check for boost leak?
i have know real reason to believe i have a boost leak, but i would really like a way to know for sure that i dont. i know you can check by spraying carb cleaner around and the motor will rev up if there is a leak somewhere, is there downsides to this method? is there any more efficient ways to do so cause its a rather beat way of checking for a leak. thanks guys
Old Aug 17, 2007 | 10:42 AM
huviduc's Avatar
Default RE: check for boost leak?
is there no better way to check or does noone know? any help would be great
Old Aug 17, 2007 | 02:31 PM
S obsessed's Avatar
You could try that, it works sometimes on vacuum leaks, only downfall as some boost leaks won't leak under vacuum pressures so it might not show up. probably the best way is to pressurize the system with air with ignition off and listen for leaks. There are tools for this or you can get creative. I put a 1 pint paint can in the accordian hose and applied air to pcv entrance into y pipe on top. it works just don't apply too much pressure, no more than what your normal boost pressure should be.
Old Aug 17, 2007 | 02:51 PM
S4LIFE's Avatar
vast and awe sell a tool that checks for boost leak. its only 25-33 dollars.
flynnr
Mar 2, 2010 07:24 AM
2fast4u66
Nov 3, 2009 10:47 PM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
a4bsix
Jul 6, 2006 04:28 PM
