Chip?
Old Apr 28, 2006 | 01:34 PM
01AudiS4's Avatar
Default Chip?
Hey,
I know this has a good chance of starting war, but I am getting a chip ASAP.
What chip should I go with, GIAC, or APR 93oct.
Anybody have documented proof that one is better than the other?
2001 S4 (Tip)
Thanks,
Justin
Old Apr 28, 2006 | 01:51 PM
ChiTowNS401's Avatar
Default RE: Chip?
I just got the APR and i love it. They're all good so just pick one and go with it. I like the APR because of the ability to switch between stock/chipped with the cruise control. Check out the websites www.giacusa.com and www.goapr.com. Theres also the REVO and a couple other ones. As far as which one is better I have no idea, I've tried searching these forums and found absolutely nothing... Although a lot of these questions have never been answered on these forums or at least enough times to be able to search and actually find something, the Search ***** seem to think so.
Old Apr 28, 2006 | 02:09 PM
sooks's Avatar
Default RE: Chip?
I dont know.. It seems to be that general opionion would say GIAC is the fastest, but harshest.. MTM is most reliable, but not as strong.. and APR is in the middle. But I dont knwo if i really by into that... ive seen fast cars in all models.. so I think its all the same really. Just pick one.
Old Apr 28, 2006 | 05:47 PM
Jestnomen's Avatar
6th Gear
Default RE: Chip?
APR and GIAC are both very reputable companies. The chips are very similar in characteristics. I would find the company with the closest distributor.
Old Apr 28, 2006 | 08:08 PM
Roadhawk's Avatar
Default RE: Chip?
Yeah - I think local support and familiarity is key. That being said I did have a problem with the APR chip - seemingly...that was fixed upon switch out to GIAC chip. I am having an issue now - with (intermitent) engine halting/bucking between 4-5K rpm that I suspect might be related to chip and programming - but don't know for sure...
Old Apr 29, 2006 | 02:46 AM
Diavan's Avatar
Default RE: Chip?
Autospeed programming.
The only issue would be not many dealers around. You gotta send it for a day turnaround.
Right now they have Stg1 & Stg2 programming for $450.
I would definitely go for that.
Old Apr 29, 2006 | 03:54 AM
Boostinalloveryou's Avatar
Default RE: Chip?
After all that I researched, and being a previous owner of a apr chip in my a4, I went with the apr chip in my s4 as well. Now not to sound conceided or anything but as of right now, I have the fastest stage 1 s4 in the country, sitting at 13.0009 @ 104.94
The tests in these links were done quite some time ago, and apr has since redone their chips with the v5 module, also the 13.0009 is on the 100 oct map as well. Well enjoy the comparisons
http://forums.audiworld.com/s4/msgs/1185070.phtml
Old May 5, 2006 | 03:30 PM
AudiS4_190's Avatar
Default RE: Chip?
your pulling a 13.0 on 261 whp? if so then u must be able to drive.......Because that is a damn good time. What is your list of bolt ons?
I have
a k&n
dirverter valves(no hp)
high flow cats
borla exhaust
apr 93 oct chip
going 100oct at waterfest.
let me know!
Old May 5, 2006 | 05:00 PM
sooks's Avatar
Default RE: Chip?
still a very impressive time.. but 100 oct can add a good half second or more. ITs a huge difference,....like 50hp
Old May 6, 2006 | 12:06 AM
Default RE: Chip?
ORIGINAL: AudiS4_190
I have
a k&n
high flow cats
borla exhaust
apr 93 oct chip
let me know!
apr v5 100 oct, 91, fault code erase, and throttle body align chip, Evo ms intake, Hyperboost diverter valves, hks turbo timer and boost gauge
