chip question
Old Jan 26, 2009 | 10:52 AM
salvageit's Avatar
Member
Default chip question
Hi guys, is there any way to tell what chip I had. I was told that it was giac when I bought the car, but I have no idea. It runs from 15-18 lbs boost so Iknow it is chiped but I would like to know what chip I have.
Old Jan 26, 2009 | 01:15 PM
meatbiscuit's Avatar
If it's chipped, you can take the cover off of the ECU and look at the actual chip itself, there should be an emblem on it.
If it's flashed, you might have to try plugging in a laptop with the GIAC flashloader installed, see if it recognizes the ECU flash, or you can try switching programs using the cruise control button if it's APR.
Not sure how you'd know if it's been flashed by another like Dhalback or MTM.
Can you ask the previous owner?
Old Jan 27, 2009 | 09:11 PM
bottlecap's Avatar
i know apr only runs like 14.5 and giac runs higher so id put my money on giac
Old Jan 27, 2009 | 09:18 PM
SourDieselS4's Avatar
APR runs more that 14.5 psi. More like 18psi
Old Jan 27, 2009 | 09:19 PM
APR runs more that 14.5 psi. More like 18psi, if it only ran 14.5 it wouldnt be nearly as fast as other chips, and it is.
Old Jan 28, 2009 | 12:24 PM
Yah, from what I've seen the newer stuff from APR and GIAC are almost identical. GIAC might be a little bit more aggressive, but not much.
Old Jan 28, 2009 | 12:32 PM
APR just dosnt work well with k04's. Otherwise its great.
Old Jan 28, 2009 | 03:40 PM
I don't know much about APR's K04 tunes. Are they shitty? Or are you talking about running an APR K03 tune on K04s?
Old Jan 28, 2009 | 09:04 PM
I mean k04's on a APR k03 tune. GIACx works better. APR k04 tunes tend to be on the conservative side if i recall, i think you can only get them with the rediculous $9000 kit.
Old Jan 28, 2009 | 11:56 PM
bottlecap's Avatar
hmm i forget where i got the idea that apr only runs 14.5psi. 18 sounds much more reasonable
