climate control trouble
Old Mar 13, 2008 | 01:19 AM
washyourrhands's Avatar
Default climate control trouble
if i have the ac on anything higher than low it shoots out like 80 degree heat when i want it like 70 btw its like 60 degrees here and it says its -3 on the instrument cluster
it fluctuated like one day it was 50 degrees out and it said it was -40
i dont know what the problem could be
i did a search and it doesnt seem like anyones had this problem
do i need to clean something or is it gonna be one of those expensive fixes?
i can live with it but i like sometimes not having to have the windows down constantly without the car fogging up instantly
Old Mar 13, 2008 | 09:54 AM
audi ops's Avatar
Default RE: climate control trouble
wellthat's definately sounding like your temp sensor is gone haywire in the front bumper. It is located closer to the driver side, pull the fog light cover straight out and also take out the inner plastic fender in the wheel well out and look around you could see it and it looks like a bigger (1'-1 1/4') mono jack, kinda. Or it could a couple other weather sensors but check into that one first.
Old Mar 13, 2008 | 04:08 PM
2k S4's Avatar
2nd the temp sensor.
Old Mar 13, 2008 | 07:33 PM
what should i check for when i get there?
like if its way dirty or should i buy a new one and how much does that typically cost?
Old Mar 13, 2008 | 07:54 PM
2k S4's Avatar
ORIGINAL: washyourrhands
Just buy a new one, & change it out.
Old Mar 13, 2008 | 11:18 PM
aiight should i buy it through the dealer or is there like a really good discout oem site?
Old Mar 14, 2008 | 01:33 AM
alright so i found two parts for air temp sensor
tell me if these are correct
http://www.car-stuff.com/carparts/au...-17341981.html
or
i found one on germanpartsonline.com
and the link liek wont copy so heres a link to the pic of it
http://img.eautopartscatalog.com/liv...5235839OES.JPG
hopefully thats all i need cus its cheap=]
Old Mar 16, 2008 | 02:55 AM
bump
Old Mar 16, 2008 | 09:18 AM
audi ops's Avatar
my bad bro I forgot about you sorry. No, it's this:
http://www.ecstuning.com/stage/edpd/...ory=Electrical
Then click the outside temperature sensor thing.
Old Mar 16, 2008 | 01:01 PM
haha its chill man
thanks a lot!
is it a pretty easy install?
