darintake advantage
Old Mar 3, 2008 | 03:39 PM
RoboRabbit's Avatar
Default darintake advantage
ok so i was doing some searching and i know that unless you go stage III nothing more than just the darintake mod is really needed, as far as intake goes. But im wondering before stage III what does a darintake accomplish? from my understanding im guessing it just allows more air in but would it have any power advantages to a stock s4? and can you just drill some holes or is it recomended to do the whole piping and filter swap too?
Old Mar 3, 2008 | 07:43 PM
loves4's Avatar
Default RE: darintake advantage
I GOT DARINTAKE AND I GOT STAGE 2 I FELT DIFFERENCE AND LITTLE BETER MILEGE ON HIWAY
JUST WHEN YOU DO IT OLSO PUT LIKE KNN FILTER
Old Mar 3, 2008 | 11:23 PM
RoboRabbit's Avatar
allright, so i read that its bad to put in a K&N for some years because of the oil but i heard that it was fine in an 01.5, is that true?
Old Mar 4, 2008 | 12:28 PM
syxxty's Avatar
no.. pre 2001.5 and 2001.5 use the same MAF sensor and the oil will effect them both.
Old Mar 4, 2008 | 01:07 PM
SourDieselS4's Avatar
2000 used a bosch MAF which did not mix well with the K&N oil. 2001 and newer switched to the Hitachi MAF, which is generally accepted to be better. The oil wont bother the Hitachi MAF, i have had K&N for a year and a half with no problems and so have many other people.
K&N and darintake is all youll ever need untill stage 3. Comparable to other intakes that cost big bucks.
Old Mar 4, 2008 | 02:34 PM
RoboRabbit's Avatar
ok cool, thats what i had heard. so basically just drill a good couple of holes in the low part of the box(how many and what drill bit size?) and get a K&N filter. should i just get a filter that fits the box or should i do that piping mod and get a cone shaped filter?
Old Mar 4, 2008 | 03:11 PM
sweeds4's Avatar
u can do either or with the darintake. it's easier to just get the k&n, but if u want to do a little project, check out the DIY threads.
Old Mar 4, 2008 | 07:26 PM
CamoA6's Avatar
Oil will effect any MAF. Just don't over oil it. I have a K&N in mine so trust me, Im not putting down K&N. If you over oil your filter expect a lean code or something along those lines.
Old Mar 5, 2008 | 02:26 PM
RoboRabbit's Avatar
all right cool ill just keep it light.
Old Mar 5, 2008 | 03:13 PM
readimag's Avatar
yeah or jsut dont really oil it at all , or go with the home made s flow like i did for 60 bucks.
