DV HP gains?
I have a 2001 S4. It's chipped with a K&N air filter, but that's it for engine performance. I want to buy some DV's. Anyone know what kind, if any, HP gains I can expect? And what kind I should get? Or should I just save for exhaust?
YTea there will be no HP increase just smoother and better boost delivery... with your car being chipped under higher boost you will want performance Dv's or at least rebuildable ones.... The stock plactic ones are known to fail regularly when a car is pushing higher boost.
Well, you can get gains, if you are boosting more then the stock ones can handles, or if the stock ones are bad. Under high boost they can leak, so you loose that boost. But they do increase throttle response, & can increase turbo spooling. That's why people think it added HP.
But from a "gain" thing, nope, it is impossible for a DV to increase HP, unless the other one is leaking.
ORIGINAL: mattr7786
you will almost triple you horsepower to the wheels.....
