dvs?
Hi, I have a 2000 S4. When I go full throttle in any gear, sometimes at about 4000-5000 rpm the power will decrease a little for the rest of the rpm range. This doesn't happen all the time. Are the stock diverter valves leaking too much? 87000 miles now, and i know the turbos are scheduled to fail at some point, but i hope not now! Any help, Thanks!
turbos can last for 180,000 miles or 18miles. List your mods. It sounds like u have throttle cut. If it is you will need a antithrottle cut circuit check vastperformance
Thanks,
Do the 710's compare well to the forge motorsport dv's, or bailey's? And do you recommend buying the throttle cut circuit check from vastperformance? And no I do not have a boost gauge. Thanks again
i did my own dv's just buy new hoses and clamps. The 710n's are just as good at the listed and much less money. It does sound like u have throttle cut but i would check for a boost leak too. Weh running a chip you should really have a boost gauge.
