I did a search and could not find a write up on how to do an oil change, this is the first German car I've owned. I want to have directions for the first time I do an oil change. Can someone help me out? I'm ordering repair manual, but I need this done ASAP and no dealers are open. Any oils you people recommend, I was going to use Mobil Oil and filter.
thanks!
Travis
thanks!
Travis
Yes,def use mb1. Really isn't anything complicated with a oil change. Take of your skidplate, drain ur oil, loosen ur filter,tighten plug, put on new filter,and threw in some oil.
if u dont know how to do an oil change i would say not to do it.
But if u want to...
Jack up car
Put on 4 jack stands (shake car)
Take off skid plate
Drain oil plug in a correct container
Drain Oil filter
Put plug back in.
Put oil on the seal of the new filter.
Put filter on and tighten as much as u can by hand
Fill with 5-7qts
But if u want to...
Jack up car
Take off skid plate
Drain Oil filter
Put plug back in.
Fill with 5-7qts
