First time user needs some help......2001 S4
Old Sep 19, 2006 | 07:54 PM
Brandon86's Avatar
Default First time user needs some help......2001 S4
So I have a 2001 S4, it has just over 65,000 on it. When should I think about getting the timing belt changed. I also have a awe boost gauge, It usually hits about 10psi, but I noticed it's dropped a little, plus I'm losing a little oil. I'm thinkin it could be the turbos seals, but I'm not sure if that would cause me to lose boost...This is my first turbo car, so I am kinda illireate when it come the turbos. Any info would be greatly appriciated.
Thank you,
Brandon
Old Sep 20, 2006 | 02:48 PM
2k S4's Avatar
Default RE: First time user needs some help......2001 S4
You had better HOPE it's not the turbo leaking the oil!!!!!!!!!!
Generaly it's the valve cover gaskets & cam seals that leak oil.
I'd say 90% of boost leaks are either leaking DV or the TBB.
The timing best is done at 100,000mi. They really last that long. Most peole seam to change them around 75kmi.
It's a $1000+ job.
KDaviou
Feb 20, 2013 12:43 PM
Bone16
Jan 22, 2012 01:23 PM
budhani786
Jun 27, 2011 01:58 PM
Brandon86
Sep 19, 2006 07:53 PM
burtyboy
Jun 2, 2005 08:32 PM
