Fog Light Help!
Old Jun 26, 2007 | 08:37 PM
RDL's Avatar
RDL
Default Fog Light Help!
The car in question is a 2004 S4. The problem is the fog lights do not work. I checked the bulbs and they are in good shape. So I checked the fuse panel where the diagram say it should be a 15 amp fuse in the #19 spot. Unfortunately I have no fuse in the #19 spot nor are there connections if I had a fuse.
Does anyone know what spot the fuse for the front fog lights should be?
Thanks
Old Jun 26, 2007 | 09:46 PM
TKneedsS4's Avatar
Default RE: Fog Light Help!
do u have an independant foglight system? sorry not familiar with 04's. cause if the fogs run off the headlights they maybe running through that circuit and fuses. But i wouldnt think it to be that way, justr a quick suggestion.
Old Jun 27, 2007 | 07:54 AM
RDL's Avatar
RDL
This is a factory, stock, front fog lights.
Thanks
Old Jun 27, 2007 | 09:41 AM
TKneedsS4's Avatar
yea i get that part but i just wasnt sure if the 04's have the factory fogs running through the headlight or running lights system for some reason. or maybe the bulbs are just in place and the package was never finished [sm=signs003.gif]
Old Jun 27, 2007 | 12:46 PM
sooks's Avatar
I say eff it..just go get some HID's ....theyre sweet.. i dotn even use brights now..if i have my headlights and fogs on...then i switch on the high beams..it looks like shut off my lights completely..
Old Jun 27, 2007 | 08:34 PM
oooos4's Avatar
Hey sooks... The fog light relay mod helps a lot... It makes the fog light switch completely independant... So you can have the fogs on with high beam or with the headlights completely off...
Old Jun 28, 2007 | 11:43 PM
TKneedsS4's Avatar
^^^^ yes i have also done that but the topic here is about a totaly different issue with a 04 and no wires running the fog lights.
Old Jun 29, 2007 | 10:31 AM
sooks's Avatar
Yeah..ive wanted to do it.. how did you do it...and how difficult was it??
Did you do it by doing the thing where you take out that box from teh glove comparment, break off one of the tabs and solder a connection between two other tabs.
Old Jun 30, 2007 | 12:23 PM
TKneedsS4's Avatar
^ yes i odnt think u break a tab off tho or u dont need to, you just need to solder between two of the connections, very easily done and well worth it. Night rider mode. no lights on at all and running form the cops iwth just the small fogs on hahah LOVE IT
Old Jul 1, 2007 | 01:09 PM
sooks's Avatar
yeah..i gotta do it... Ive wanted to for awhile... And i love just having fogs on...and parking lights... Althoguh i dont know how knight rider id be..my fogs are brighter than my headlights
