Forge MBC Hookup
Old Jan 23, 2008 | 04:17 PM
carhopper's Avatar
Default Forge MBC Hookup
I just bought the forge MBC before I checked the forum. It appears that several people have said that the forge can't work because of the 3 prong and it definately doesn't replace the N75. Well, I took it apart and the top two prongs are straight through. This actually replaces one of the T connectors in the popular parallel diagram. Please take a look and let me know if this will work. I'm going to try it tonight more than likely. The only thing I don't like is the forge isn't a check valve, it is a tapered flange. Therefore, it will allow some air to get by all the time which may affect the ramp of boost when I want the waste gate completely closed.
[IMG]local://upfiles/33364/F1B5652F05974AF7A975545360631DCE.jpg[/IMG]
Old Jan 23, 2008 | 04:55 PM
SourDieselS4's Avatar
Default RE: Forge MBC Hookup
Yeah that diagram looks allright to me the mbc is taking the place of the T fitting that would normally join the pressure to the waste gate from the n75 and the mbc
Old Jan 25, 2008 | 05:41 PM
carhopper's Avatar
It works, but just as I suspected the lack of a check ball lets it bleed all the time, not just during the peak. This results in a limit through the whole band. I talked to ECS about not selling this any more, but they probably won't listen. Although, they are taking it back.
Old Jan 26, 2008 | 02:45 AM
typhoonfd's Avatar
what about theManual Boost Controller from vast. ive had it for a few weeks but its still sitting inmy shop, i havent put it on because of mixed reviews and i dont under stand the directions on how to install it lol.
Old Jan 26, 2008 | 08:07 AM
carhopper's Avatar
It takes 10 minutes. Just follow this diagram. Look at the flange on the picture to be sure you use the correct output and input.
[IMG]local://upfiles/33364/5F98DBDFE4B44A5AA5A596F25323A62F.jpg[/IMG]
Old Jan 26, 2008 | 10:34 AM
typhoonfd's Avatar
man thats great, thanks. that pic makes a lot more sence than the one on vast. im getting real bad boost spikes from ***** to the wall 22psi to a steady 15. i want to try to keep it at a steady 15psi. i like the power i get from 22 but it sucks to feel that unsteady surgein power id rather have it smooth. i did a post on this before a got a lot of good infobut never got a good answer to my question(how to stop boost spikes). but any other info would be great. i wonder why people dont like to use mbc without ko4s.thanks again
Old Jan 26, 2008 | 03:17 PM
readimag's Avatar
i dont know if this helps at all but i picked up the n75 from vast and that helped with my spikes.
Old Jan 27, 2008 | 09:32 AM
typhoonfd's Avatar
i think i will order the vag-com andtryto do atest then if i need ann75 i'll order it. i dont know because i turned the chip off and the car holds a stedy 5psi and sometimes it goesto 6psi. we will see.
Old Jan 27, 2008 | 02:22 PM
01AudiS4's Avatar
What would happen if you removed the N75 and ran just the MBC?
Old Jan 29, 2008 | 10:40 AM
patty AT forge's Avatar
This is our ball and spring MBC, the other two models we manufacture are bleed type:
http://www.forgemotorsport.com/conte...product=FMUNOS
