Garage door opener on sunvisor?
Old Mar 1, 2005 | 01:19 PM
coletrain's Avatar
Default Garage door opener on sunvisor?
Anyone know how to program the garage door opener on the sunvisor? I dont find anything in the manual (2001 S4)
Old Mar 1, 2005 | 03:52 PM
SAxeman@verizon.net's Avatar
Default RE: Garage door opener on sunvisor?
1. Turn on the ignition switch on.
2. Simultaneously press and hold the first and third buttons and releasing only when the indicator light begins to flash after about 20 seconds.
3. Hold the end of the hand held garage transmitter about 2 inches away from the surface of the HomeLink channels while keeping the indicator light in view.
4. Simultaneously push the hand held garage transmitter and one of the HomeLink channels. Do not release until the next step is completed.
5. The HomeLink indicator light will flash first slowly, and then rapidly. When the indicator light flashes rapidly, both the button and the channel may be released.
Repeat for each of the buttons for different garages or other remote devices.
If you have a garage door with a rolling code, follow the directions below:
1. Locate and press and release the training or learning button on the garage door opener motor head unit.
2. Return to the vehicle and pres and release the programmed HomeLink channel. Press and release the HomeLink channel a second time to complete the programming process. Some garage doors openers may require you to do this procedure a third time.
Let me know how it works.
Old Mar 2, 2005 | 02:43 PM
99a4audi's Avatar
what he said ^
Old Mar 3, 2005 | 01:31 AM
coletrain's Avatar
Thanks!!!!!!!!!!!!!!!!
Old Mar 4, 2005 | 01:15 PM
clconversion's Avatar
in your owners manual it should tell u how to program this but u could also read what SAxeman said
Old Dec 28, 2007 | 08:52 PM
eagle_ca's Avatar
thanks SAxeman, it finally works for my 99 Audi A6.
steps i triedis:
2. Simultaneously press and hold the first and third buttons and releasing only when the indicator light begins to flash after about 20 seconds. ( clearn or reset)
3. Hold the end of the hand held garage transmitter about 2 inches away from the surface of the HomeLink channels while keeping the indicator light in view. (prepare)
4. push one of the HomeLink button you like to program. Do not release until The HomeLink indicator light will flash first slowly and continue hold it, use another handpush andheld garage transmitteruntil the indicator light flashes rapidly, thenboth button and the channel may be released.
Repeat step 2-4 for each of the buttons for different garages or other remote devices.
Old Jan 2, 2008 | 08:28 AM
Burzum's Avatar
I moved into a new house and just did this yesterday. I think it's page 142 in the B5 manual.
Old Jan 2, 2008 | 12:02 PM
TKneedsS4's Avatar
or u just pull a baller move like I. and have electric dumps wired to the homelink buttons . MUHAHAHA!!!!!!
Keeping it sleeper.
Old Jan 2, 2008 | 02:54 PM
Burzum's Avatar
ORIGINAL: TKneedsS4
Keeping it sleeper.
Oh? Sounds interesting. I would have thought the homelink was self contained. How'd you wire it to dumps? Also.....what's a dump
Old Jan 2, 2008 | 05:39 PM
Cliff218's Avatar
nayone got an opener to replace a bad one?
