grinding noise
Old Nov 29, 2004 | 05:45 PM
scoops42's Avatar
Default grinding noise
I have a 2000 S4. I drove it to school this morning and after class i went out and started it and noticed a grinding noise coming from the engine. It doesnt sound like it is coming from the tubos but it could be. I have never heard this before. Also it is not consistant noise. After checking things out i notice that the check computer light came on. I was wondering what could be causing this noise could be?
Old Nov 29, 2004 | 05:49 PM
Jestnomen's Avatar
6th Gear
Default RE: grinding noise
do you have a VAG-Com or access to one? You could also take it to Autozone to have the CEL code scanned. If the light is flashing then DO NOT drive the car anymore, have it towed to a mechanic. If you get the code post it here, and i'll try to help.
Old Nov 29, 2004 | 06:02 PM
scoops42's Avatar
No i dont have a vag-com or access to one. The light is not flashing. Also what is Autozone? Is it just a parts store? ill aska around to see if i can get a vag- com though. thanks.
Old Nov 29, 2004 | 06:07 PM
Jestnomen's Avatar
6th Gear
Hehe, yeah its an autoparts store. Where are you from?
Old Nov 29, 2004 | 06:49 PM
scoops42's Avatar
I am From Bend Oregon. We dont have a Autozone here so ill try like Schucks or a couple of other places here.
Old Nov 30, 2004 | 12:04 AM
Driv3n's Avatar
If the noise was coming from the front end, you might be abusing the clutch and have blown your transmission. When my friends blew his transmission there was a grinding noise.
Old Dec 1, 2004 | 03:05 AM
scoops42's Avatar
I found someone with a cel reader. The codes are P1136, P1347, and P0300.
Old Dec 1, 2004 | 06:14 PM
scoops42's Avatar
Alright I found out what the codes are
P1136- Bank 1 Mixture adaption too lean
P1347- Bank 2 Crank/Cam Sensor out of sequence
P0300- Cyl. misfire Detected
Would any of these cause the noise that i am hearing from my engine?
Old Dec 1, 2004 | 07:28 PM
Jestnomen's Avatar
6th Gear
The P1347 code kind of scares me, I would go get your car looked at by a professional.
Old Dec 1, 2004 | 07:59 PM
scoops42's Avatar
yeah it scares me to. I wonder if the crankshaft would make grinding sound?
