Help with DTC code
Old Feb 14, 2009 | 02:13 AM
poorboy533's Avatar
Default Help with DTC code
I have CE light on recently car works great (2001 S4 ((no mods)) DTC code is P0741, what caused to code and what do I do about it ??
another question , I have an oil leak front of motor above the oil filter somewhere up high, any ideas whats leaking, anything common with this issue, I know there numerous hoses right there hopefully a bad hose somewhere
Thanks
Jesse
Old Feb 14, 2009 | 09:20 AM
SourDieselS4's Avatar
I looked it up and got this, Im not familiar with this one so i dont really know what to say. Its obv a tip right? Hopefully someone else can help you out. Go to audizine.com and search for P0741 in the B5 S4/RS4 section, im sure youll get a few threads to readthrough, might help.
7125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
Possible Causes
  • Automatic Transmission Fluid (ATF) Level not OK
    • Transmission Sealing faulty
  • Automatic Transmission Fluid (ATF) dirty
  • Torque Converter faulty or incorrect Torque Converter installed
  • Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218) faulty
  • Torque Converter Pressure Valve faulty
  • Valve for Torque Converter Clutch faulty
  • Torque Converter Lock-Up Clutch faulty/worn our
Possible Solutions
  • Check Automatic Transmission Fluid (ATF) Level
    • Check Transmission Sealing
  • Check Torque Converter
  • Check Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218)
  • Check Torque Converter Pressure Valve
  • Check Valve for Torque Converter Clutch
  • Check Torque Converter Lock-Up Clutch
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
