how 2 take cruse control stalk out ?
Old Apr 22, 2006 | 11:19 AM
Audis42001's Avatar
Default how 2 take cruse control stalk out ?
can anyone tell me how 2 take the cruse control stalk out ? of an audi s4 2000
Old Apr 22, 2006 | 03:02 PM
dankhound's Avatar
Default RE: how 2 take cruse control stalk out ?
Disconnect battery. Loosen 2 t30 screws in the back of the steering wheel to remove the airbag. You must also remove connector for airbag. Yes the screws are in those holes and no they dont come all the way out. Make sure you lay the airbag face up. Remove bolt for steering wheel. Its either a 10 or 12 triple square. Always replace bolt. The spiral sprink is next. Its just clips onto the signal stalks in four places. Also remove any relevant connectors. Next loosen the band that hold the switchs to the steering column. Pull both switchs off the column. Remove and screws holding the two pieces together. It may just clip together. You should be able to look at the new one and see how the two stalks are connected.
Old Apr 23, 2006 | 03:29 PM
Audis42001's Avatar
thanks man i appriciate it
staletime
Oct 2, 2013 10:53 PM
jgw5k
Jun 19, 2012 08:59 AM
RayPag
Dec 26, 2010 10:55 AM
kstrike155
Sep 15, 2006 01:02 AM
Audis42001
Apr 22, 2006 01:05 AM
