K04 Questions
I few weeks ago one of my K03s went out at 65k. Anyway I will be replacing them with RS4 K04s. I am under the impression that the only parts I need are the turbos themselves, the RS4 inlet pipes to the turbos and gaskets for the turbos. Are only new inlet pipes suffecient or do I need to get all RS4 intake components?
Also is there any other work I should get done while the engine is out? I am currently planning on replacing the timing belt, clutch, accessory belt, water pump, thermostat and motor mounts.
Yes, all you "need" is...
1. L & R K04's
2. RS4 Inlet Pipes
3. RS4 K04 hardware
That's it! You should also have....
1. Downpipes or Piggies
2. exhaust
3. GOOD DV's
4. GIAC X or some other chip made for K04's with stock MAF & injectors
5. New clutch
6. Snub mount or trans brace
So in the big picture it's more then the $3000 for the K04 "kit"
1. L & R K04's
2. RS4 Inlet Pipes
3. RS4 K04 hardware
2. exhaust
3. GOOD DV's
5. New clutch
ORIGINAL: 2k S4
1. L & R K04's
2. RS4 Inlet Pipes
3. RS4 K04 hardware
2. exhaust
3. GOOD DV's
5. New clutch
1. L & R K04's
2. RS4 Inlet Pipes
3. RS4 K04 hardware
2. exhaust
3. GOOD DV's
5. New clutch
