Locks not working?????
Old Sep 25, 2007 | 05:32 PM
Ruggedboy's Avatar
Default Locks not working?????
Hey guys, I wonder if I can get some help here? My locks just stopped working, I can’t open or close them with the remote or from the lock switch on the driver side door. All I can do is open and closethe driver side door with the key. My alarm is working fine, the remote is arming it & disarming it fine. I do have the blitz turbo timer, but the in-line fuse is good & all other fuses are also good. Is there a relay I should look at? I’m really hoping it’s not the central locking module. I don’t have a VAG, just a OBD 2 scanner which won’t do anything for me as I have no check engine light on. Any suggestions would be great, thanks….
Old Sep 25, 2007 | 08:38 PM
2k S4's Avatar
Default RE: Locks not working?????
My bet is the TT, Vag it for codes, the central lock will throw codes.
Old Sep 25, 2007 | 09:28 PM
Ruggedboy's Avatar
OBD 2 scanner and a VAG are two different things????
Will my OBD 2 scanner pick up these codes?
Old Sep 26, 2007 | 10:51 AM
2k S4's Avatar
ORIGINAL: Ruggedboy
Yup, you can read stored codes that will not throw a CEL. You can also test the locks air pump.
Old Sep 26, 2007 | 11:43 AM
S4rat's Avatar
i had the same problem with mine too, my key hole in the steering collum was not making a connection when the key was off so it was thinking the key was still in when it wasnt and wouldnt alow me to lock the doors remotly only with the key physically
terenkleon
Feb 3, 2012 02:51 PM
Silente
Jun 24, 2011 11:13 AM
rfarl290
Dec 28, 2010 08:27 PM
kmitch
Aug 5, 2009 09:19 PM
