Long Term Fuel Trim p1139 & p1137
Old Jul 25, 2006 | 11:32 PM
RCFerrari's Avatar
Default Long Term Fuel Trim p1139 & p1137
Hello,
Over the past couple weeks, I have had some problems with LTFT with codes p1139 & p1137.
I have seached the forums and came up with little regarding those 2 codes. I cheched for vacuum leaks and didn't find anything significant. The only mods I have on my car are a stupid air filter. Nothing else.
You help is GREATLY appreciated!!! Any suggestions would be fantastic (other than taking it to the dealer).
Thanks!
Chris
Old Jul 26, 2006 | 04:03 PM
techbod's Avatar
Default RE: Long Term Fuel Trim p1139 & p1137
P1139 is the problem, low fuel pressure, injector (s) leak, EVAP cannistor purge valve
Old Jul 26, 2006 | 09:56 PM
RCFerrari's Avatar
So what do you suggest... maybe changing the fuel filter?
Old Feb 3, 2007 | 04:49 PM
vendingman2000's Avatar
I also have a long term fuel trim problem on my 01 audi a4 quattro only add on is a k&n air filter. Last time a code popped up was mass air flow sensor i took it out and cleaned it with alchohol code went away and car ran better. This sucks please help!
Old Feb 3, 2007 | 04:55 PM
techbod's Avatar
canister purge valve mate seems to be a common fault over there perhaps it should be taken up with Audi as a recall issue because of the low octane fuel there, in the UK the lowest is 95 Ron
Old Feb 3, 2007 | 08:57 PM
DevilS4's Avatar
Mine threw those same codes with a vacuum leak right before the fuel pressure regualor, also could be oil from the K&N or whatever filter you have clogging up the MAF.
Old Feb 4, 2007 | 12:26 AM
RCFerrari's Avatar
The issue for me ended up being the Mass Air Flow sensor... There was also of black carbon build-up on the eliments so I took a few Q-TIPS and carefully cleaned the elements. I sprayed the QTIPS with throttle body cleaner and then carefully cleaned.
The FT codes never returned for obvious reasons.
Old Feb 4, 2007 | 12:28 AM
RCFerrari's Avatar
It was easy to fix... Clean your Mass Air Flow Sensor with Q-Tips and throttle body cleaner. I never got the problem again. The filament on the MAF was completely carbonized...
whitey
Dec 17, 2010 11:47 AM
mandito219
Feb 7, 2010 07:03 PM
daveck2
Sep 24, 2009 05:40 PM
smahar
Aug 7, 2009 10:58 AM
vendingman2000
Feb 3, 2007 05:10 PM
