Lost Half boost pressure and CEL
Today at a stop light I through a CEL and lost boost pressure. I usually run about 12psi and I am down to 6. The car idles very rough and there was a bad smell in the air around the time this all happened. I don't have a code checker so any ideas what may be happening?
Thanks.
Thanks.
more than likely a boost leak. There is a possibility that one or both EGT sensors could be bad. That would result a boost loss.....i drove mine for3 months with6 lbs
because of those sob's Hopefully thats not the case since there pretty expensive. Probably a boost leak though.
how long has it been since you changed your spark plugs?
Following that, it may be a coil pack. You can confirm by swapping in a known good coil pack (ie. brand new, or one from another cylinder and see if the misfire follows the #1 cylinder coil pack).
Following that, it may the ICM.
No there were two of what was replaced ( I watched him do it). They were located under the plastic piece to the far left of the engine and I could have sworn he said Iginition Control Unit, but maybe it was an ICM. Are there two of those?
