Low Oil Pressure UrS4
Old Jun 11, 2007 | 08:57 AM
audisnut's Avatar
Default Low Oil Pressure UrS4
Ever since i got my urs4 the oil light comes on all the time.
It says that the oil pressure is low.... I did change one of the Oil Pressure Senders thinking it would fix the problem but its not it. I was gonna change the oil pump but that itself is $465.... I called the audi dealer they said they never sold an oil pump and that it could be some wiring problem? anyone have any idea what it is?
Old Jun 11, 2007 | 10:05 AM
GeilKyle2's Avatar
Default RE: Low Oil Pressure UrS4
First thing I would do is hook up a gauge and check the actually oil pressure to see if it is low. How many miles, what weigh oil are you running?
Old Jun 15, 2007 | 04:48 PM
audisnut's Avatar
its got 220,000 mi, i use synthetic oil, thats what i was going to do the oil pressure and see what it is...
Old Jun 15, 2007 | 08:44 PM
s4treet rat's Avatar
thats kinda alot of miles as your car gets old the crank and cam and rod bearing wear and there is more clearance in between the crack,cam and rods for oil to fill this gives you low oil presser or you may have a short to ground on the oil sensor. thats all i could think of right now good luck dude
Old Jun 25, 2007 | 08:54 AM
audisnut's Avatar
i checked the oil pressure it was 32 psi...
Old Jun 25, 2007 | 10:42 PM
Artrip's Avatar
at what engine speed. General rule of thumb is that you should have 1 PSI for every 100 RPM of engine speed, so at 1000 RPM, you should have AT LEAST 10 PSI, and at 6K RPM, you should have60 PSI.
Old Jun 26, 2007 | 12:33 AM
SickBoy's Avatar
ya my dad keeps having this problem with his allroad but ill check the oil psi.
pdxrado
Jan 28, 2013 06:35 PM
WinnipegURS4
Jan 5, 2011 02:40 PM
deephouse
Feb 14, 2008 03:36 PM
audisnut
Oct 9, 2007 02:45 PM
