MBC?
To get any performance gain from an MBC you have to run it stand alone and should get a GIAC-x chip and TCD (diode mod). When running it parallel it just clips boost spikes. Without the chip (giac-x works best) the ECU wont cope well or at all, and without the Throttle Cut Defender you may experience throttle cut.
If you have k03's the only real use for an MBC is to completely max out your turbos (past what a chip requests). Which will most often leads to this: http://www.youtube.com/watch?v=RhOMp...eature=related
