Might be normal boosting behavior
Old Aug 19, 2010 | 04:00 PM
IseeSlowPeople's Avatar
Default Might be normal boosting behavior
This problem (or not) that I'm seeing is a constant thing. At WOT in lower gears, 1st and 2nd, boost spikes to about 19psi then rapidly drops to about 13-14psi then I'm ready to shift. At the higher gears when I do this the boost holds better, maybe only dropping off a couple of psi from 19 to 17psi.
I'm thinking that maybe this is normal for a Giac tune that I have from Awe. Other mods are: Autobahn hose kit w/Tbb, Bailey DV's, Awe catback, K&N airfilter with modded air box and MBC.
Also I recently changed the fuel filter and always 91-93 octane. This week I am doing a boost leak test.
Old Aug 19, 2010 | 05:56 PM
josh_easlon's Avatar
Sounds like normal boosting to me. You'll generally spike around 19 and drop a bit in the first couple gears, and sustain a higher boost in higher gears. I wouldn't worry about it, but there is no harm in doing a boost leak test every once and a while :-).
Old Aug 19, 2010 | 11:17 PM
bigern45's Avatar
sounds normal, these K03's are WAY out of their efficiency @ 19 psi and 5000+ rpms...
Old Aug 20, 2010 | 08:23 AM
That's what I was thinking. Thanks for the input guys!
DanaB6
May 23, 2012 01:34 PM
james0013
Aug 16, 2008 01:32 AM
a42point8awd
Feb 9, 2008 10:16 PM
gotBoost?!
Sep 9, 2007 07:59 AM
falcompsx
Mar 24, 2007 10:34 PM
