Misfires, No Brakes, Super bad Idle,*** UPDATE: IT WAS THE W/M KIT!!!!***
Old Apr 23, 2008 | 02:05 AM
  #31
Audi_Skydiver's Avatar
Default RE: Misfires, No Brakes, Super bad Idle, Searched, Still Nothing
Not yet. I am going to do that tomorrow.
I am kind of thinking that my headgasket might have already been on it's way out. Over the last few weeks I have noticed a little bit of white smoke coming from the exhaust when the engine was cold. I figured it was just condensation but now that i look at it, with the outside air temps and whatnot I don't think it should have been doing that. Maybe the headgasket was leaking before but only when cold. Once it warmed up maybe the engine expanded enough to stop the leak or at least slow it down enough to make it so you could not see any smoke. IDK it's all speculation right now.
Josh
Old Apr 23, 2008 | 08:04 AM
  #32
sweeds4's Avatar
Have your posted this on Audiworld? Probably more technical responses! I dont know if AZ helped at all?
Good luck!!
Old Apr 23, 2008 | 10:47 AM
  #33
hiwords's Avatar
hey i'll trade you my car plus 5g for your car? mine runs great hehehe. j/k i doubt you would do that anyways but it's the only suggestion i've got since you've done everything that i was going to says. as for the brakes, i think it's probably a vacuum issue.
Old Apr 23, 2008 | 11:05 AM
  #34
I'm guessing you didn't see that the engine is blown up? That would cause all my problems.
Josh
Old Apr 23, 2008 | 11:21 AM
  #35
sweeds4's Avatar
ya i just saw that the head gasket blew. What is that going to cost?
Old Apr 23, 2008 | 11:27 AM
  #36
Here is something else.
I had been getting a little bit of white smoke for a while (about 2 weeks or so) before this all happened. I am wondering if this was something that happened before and then it just so happened to go out because of the extra boost and whatnot...
blown head gasket would mean white smoke right? coolant leaking into the combustion chamber? There was not that much smoke though. Only on startup and for about 10 min after that. Maybe it was only a small leak at first so it was just seeping into the chambers overnight or when the engine was cold and once the engine heated up it sealed it enough for there not to be enough leaking to cause noticeable white smoke? Just thinking out loud right now.
Josh
Old Apr 23, 2008 | 12:11 PM
  #37
ditallow's Avatar
If you don't trust the the technician you have I would recommend you to buy a crate engine instead of rebuilding a new one.
My guess it would be cheaper to get a crate engine but what do i know!
anyways good luck .. you need it
Old Apr 23, 2008 | 12:22 PM
  #38
Superdug's Avatar
SoCal Crew Member/White Devil
Josh if you have 0 compression you sometimes need to pull the piston for new rings and such. If I were you I would **** that thing out of there and then why your in there have all the motor work done and build yourself a solid long lasting motor. but I defintley recomend an engine pull your life should be a lot simpler. well good luck if it's just a head gasket you should be able to leave it in with out to many problems. I just like pulling motors so thats my first response.
Old Apr 24, 2008 | 12:12 PM
  #39
So how difficult is it to pull the engine? I mean can I do it in a day or two?
Anyone have any good resources as to step by step or something like that?
Josh
Old Apr 24, 2008 | 03:37 PM
  #40
hyperlight900's Avatar
go on audizine and look under the s4/rs4 forum theres a guy doing turbo swap and he has a pretty extensive diy for engine pull check it out.
oh and just for reference theres a guy i kow locally that can pull the engine and tranny in 2 hours lol it just depends on how good you are. and deff
check out the thread on audizine man very very extensive heres the link link
good luck man and i have a fear that my head gasket is doing the same thing lol i have occasional smoke too but it goes of after awhile and i have a misfire in 2 4 and 6
so hopefully its not that and its just that my new k04's are deffective lol much easier to do those....... god sometimes i hate this car lol but i love it most of the time haha
