NO ONE CAN HELP ME!! NO one can answer my ? BOOST ISSUE
Old Sep 23, 2007 | 11:22 AM
S4speedfreak's Avatar
Default NO ONE CAN HELP ME!! NO one can answer my ? BOOST ISSUE
Hey eveyone, I seem to be having a boost issue with my 00" S4. I don't seem to have the entire NUT out of the turbos I should. I still have power but not that infamous torqueiness from 2500-4500 rpms. It just seems to stay a steady slow climb but a SLow Climb.
First to say I just replaced all the hoses with samco hoses because I thought it was boost leaksSame problem No such change. Then Iwas told to change the Diverter valveswhich I changed with brand new 710p's out of a porshe 911 because I have a hopok up at porshe. Still No change in issue. Then someone told me to pull out the stock computer and put in my apr chipped ecu, and I had the same problem just a little faster of a slow climb if you get my drift. Any suggestions?? Someone also told me it may be the plugs and coils?? Or a computer code misfires maybe that I didnt erase??Anyone out there that can Help me would be a big help!
Old Sep 23, 2007 | 11:40 AM
2k S4's Avatar
Default RE: NO ONE CAN HELP ME!! NO one can answer my ? BOOST ISSUE
First, check for stored codes, your answer may be in there.
You never checked or replaced the TBB, or did you get the Samco?
You should log block 115 with Vag-com & see what the requested vs actual boost is.
My guess if there isn't a leak, that either your MAF or N75 is failing.
Old Sep 23, 2007 | 11:48 AM
2ks4 Thanks for at least a place to start. I replaced the TBB with the samco so I shouldnt be haveing any rips or leaks.
Old Sep 23, 2007 | 11:49 AM
where can I buy a vagcom??
Old Sep 23, 2007 | 12:10 PM
2k S4's Avatar
ORIGINAL: S4speedfreak
Got & read the FAQ.
http://www.ross-tech.com/
One thing you can do right now, is unplug the MAF & see if it runs better, if so, bad MAF.
b312chi
B8 Models
Aug 12, 2013 05:12 PM
hotswaps
Aug 8, 2013 05:50 PM
hotswaps
May 27, 2013 07:02 PM
kerNol
Nov 28, 2008 10:13 PM
cu52
Dec 1, 2006 12:53 PM
