ouch!!! these codes hurt!!
Old Sep 6, 2009 | 01:49 AM
bigern45's Avatar
Default ouch!!! these codes hurt!!
so i went to the track yesterday and while i was running i got a ses light.. didnt think anything about it but maybe misfires from running to rich.. so i go ahead and run a few times and still hit a 12.9 with cel on.. get home and find these codes..p0341 and p1347. all about cam codes and stuff.. havent done vagcom yet.. and get this. warm idle vacuum is at 14 inches of mercury.. so somethings not right.. was thinking possibly timing belt jumped a tooth or cam adjuster is bad.. ima do some testing tomorrow with vagcom and see whats up...
Old Sep 6, 2009 | 11:41 PM
bigern45's Avatar
so.. if the cam adjusters stop working does this sound like a feasible problem that could occur?? i really think that a cam could be off as well.. i ran it pretty dang hard.. hot lap after hot lap.. i think the belt and tension-er just gave a little bit.. ill have the front clip off and know whats up with the timing by tuesday.. if its good ill look cam tensioners and such.. i guess ill double check the sensors as well..
Old Sep 7, 2009 | 12:12 PM
Mott Power's Avatar
sounds like it; have you replaced the tensioner recently?
Old Sep 7, 2009 | 04:59 PM
bigern45's Avatar
nope.... but before i bought it the guy showed me receipts where the tbelt, tensioner and water pump all had been done about 10k before.. so its only got 20k on this tbelt and water pump..
Old Sep 8, 2009 | 08:13 PM
bigern45's Avatar
so.. try to hear a boost leak, as my tools are limited at home.. i dont hear anything.. so i decide to snoop around the cam adjusters. thats were i notice timing belt fragments.. fibers and cord. get the cam covers off and geezz... belt is frayed and loose.. and off a tooth..
i hate being right sometimes..
Old Sep 8, 2009 | 11:41 PM
Mott Power's Avatar
"well, there's your problem..."
Old Sep 10, 2009 | 12:43 AM
bigern45's Avatar
cams were in sync with each other but off two teeth to the crank, retarded.. not advanced.. so.. it ran so good up to the point of me tearing down.. does anyone know if i bent a valve??
Old Sep 10, 2009 | 09:49 PM
Mott Power's Avatar
i've heard of guys skipping a tooth or two and being fine, if you're worried then run a compression test
Old Sep 10, 2009 | 09:55 PM
bigern45's Avatar
Default No bent valves!!!
so i pretty much talked to a few guys and they told me the same thing.. off two teeth.. gotta just throw a belt on there and see what happens.. well. put on a belt, lined it up.. new tensioner, guide and everything.. fired up and purred like a kitten. no issues. no misses. pulls hard like a beast.. so apparently your belt can jump two teeth without bending a valve. so just an fyi so you all know.. lol...
Old Sep 18, 2009 | 04:44 AM
jibberjive's Avatar
Go back to the track now Have you ran it at the track previously? If so, what did it run?
