P1122 and P1140
Old Mar 19, 2008 | 10:20 AM
audiS4jls's Avatar
Default P1122 and P1140
I have a CEL and so I went to Advanced Auto and had them scan it, they got P1122 and P1140.
I've searched the forums and google and I get different descriptions as to what the codes mean. Will someone give it to me in layman's terms? I don't know much about 'wrenching' but I'd like to learn.
Is this a simple fix and if so, can someone please guide mein the right direction?
Old Mar 19, 2008 | 11:01 AM
godowninflames's Avatar
Default RE: P1122 and P1140
17530 P1122 O2 Sensor Heater Circ.,Bank2-Sensor2 Open17548 P1140 Bank2-Sensor2 Internal Resistance too High[align=right] [/align]
Old Mar 19, 2008 | 11:05 AM
you just need some new o2 sensors which you can get from www.vastperformance.com
Old Mar 19, 2008 | 11:14 AM
audiS4jls's Avatar
i went to the site and found oxygen sensors and widebandoxygen sensors... i'm assuming the regular one is ok?
how difficult is install?
Old Mar 19, 2008 | 11:34 AM
http://vastperformance.com/shop/prod...products_id=69
You can select either front or rear sensors, you need front (pre-cat) which is bank 2. Replace both sensor 1 and sensor 2 while you're doing it since vast sells them in pairs.
Old Mar 20, 2008 | 10:36 AM
audiS4jls's Avatar
seems like i can fix both issues by replacing the rear o2 sensors...
iread it's easier to fix the rear sensors as they are visible and easy to get to...
do you happen to know of a DIY guide for this sort of replacement?
Old Mar 21, 2008 | 09:46 AM
Bank 2 is the front or pre-cat sensors. Replacing the rear won't do anything, but yes they are easier to replace.
Old Mar 21, 2008 | 11:02 AM
techbod's Avatar
not first O2 sensor but second and its the heater side that's gone down ( HO2S ) BANK 2 SENSOR 2, check for burned/broken wires to that sensor
Old Mar 21, 2008 | 01:47 PM
audiS4jls's Avatar
probably best to just have the shop do it then if it's the front ones
Old May 31, 2008 | 08:38 AM
mikehh's Avatar
How did you ever make out?? I have the same codes.... does anyone else have some input?
