rear wheel hop
Old Sep 13, 2009 | 06:51 PM
bigern45's Avatar
Default rear wheel hop
hey, just trying to figure out which mounts i need to eliminate rear wheel hop. i drop the clutch at 5000 and it seems as though the rear diff slams up and down on the bottom of my car.. do i just need one mount back there or are there a few that i need to get??
Old Sep 13, 2009 | 07:46 PM
digdgb's Avatar
Member
Old Sep 14, 2009 | 07:33 AM
SourDieselS4's Avatar
Carefull bro... dont want to break anything. Alot of people end up breaking the OEM diff carrier/crossmember. Sometimes this trashes the rear diff and both rear axles too. I see alot of this on the other forums...
To lock that down you want 034's billet rear diff carrier, new mounts, and subframe bushings. There are a couple options for mounts and subframe bushings. I got the basic 034 density line but theres also SOLID subframe bushings. 034 is definitly the place to go, itll be a few hundred bucks to lock everything down.
http://www.034motorsport.com/product...ducts_id=19278
These are the solid subframe bushings, i have density line they arent as good but i bought them before this stuff was out.
As far as launching most people would tell you not to drop the clutch, and your RPM might be a little high. You should let up on the clutch untill right before it grabs then blip the throttle and feed out the clutch on the upswing of the RPM quickly but also in controll. The shock of dumping the clutch tends to break ****. And you only want enough RPM so you dont bog about 4000rpm should do it... This way will cut you the fastest 0-60 and wont break stuff on the car
http://www.youtube.com/watch?v=59Rt9...eature=related
yellow_submarine
Jul 8, 2017 03:01 PM
Kyle_vdk
Jan 11, 2014 10:25 PM
wardhill
May 16, 2012 08:06 AM
audiaa6.2000
Apr 17, 2011 08:26 PM
southcoast
Apr 27, 2007 10:25 PM
