Remove CV axle
Old Mar 20, 2007 | 03:56 AM
i3uddha's Avatar
Site Moderator/Ninja
Default Remove CV axle
Its about that time [&o]...Im ordering from raxles.com
were replacing both front axles...... WRITE UP HERE
just wanted to see if there was anything in particular we should be looking out for
(trouble spots etc.) & maybe tools needed...just incase were missing the obvious..
& unfortunately we'll be doing this "sans" lift....
Old Mar 20, 2007 | 07:02 AM
zrwhat's Avatar
Default RE: Remove CV axle
a pry bar would help
Old Mar 20, 2007 | 02:09 PM
i3uddha's Avatar
ORIGINAL: zrwhat
why stop there... sledgehammer !
that wouldn't be too good in my hands around my car.. lately ive been pretty upset w/ her..[:@]
Old Mar 20, 2007 | 03:57 PM
Coop's Avatar
triple square sockets, cake job...why you replace and not just reuild?
Old Mar 20, 2007 | 04:11 PM
i3uddha's Avatar
I blv the Raxles are rebuilt...
Old Mar 20, 2007 | 04:52 PM
Superdug's Avatar
SoCal Crew Member/White Devil
Isay you use a torch.
Old Mar 20, 2007 | 04:58 PM
GeilKyle2's Avatar
8mm tripple square bit
Old Mar 20, 2007 | 05:33 PM
i3uddha's Avatar
have u guys looked at the write up -
its supposed to be really simple -
just wanted to know if anyone else has used this particular method..
& I know once u get that Axle bolt out - u need to replace it w/ a new one right??...
Old Mar 20, 2007 | 05:37 PM
2k S4's Avatar
It's a very easy job. The pinch bolt on the uprights can be a PITA, remove the bolt, & spay it with Pb blaster.
The long bolt holding the axle in in the hub is in there with 300ft-lbs. So use a impact gun, or a really long wrench & cheater bar.
Don't take the bolt all the way out, leave about 1/4 in there, & tap the end with a hammer. It will loosen up the axle. DO NOT reuse the bolts.
lightly grease the ends of the axle & do not force them in, let them slide in, while just tapping the ends.
When I did my ends, the stock bolts were hex, & the ones in the kit were 19mm. I believe the hex is a 17mm? Make sure you have hex sockets.
Old Mar 20, 2007 | 08:02 PM
pyrotechnique's Avatar
I just did it via this method and it was super easy! Just do as they say and after you've removed all the bolts holding the cv axle in, just jack up the wheel hub assembly as high as you can and the axle will come right out. Make sure you have your wheel turned to the right though. If you don't, when you pull the cv axle out it will pop out the wrong way and it will be blocked by the shock, if that makes sense.
