Running SUPER lean using the W/M kit???
Ok, So I got my A/F gauge installed the other day and tonight I got it all calibrated and working correctly. Then I went out on a test drive. What I saw is REALLY scaring me.
When I am just cruising around my A/F stays around 14.3-14.5 which is pretty much were it should be. However as soon as I get on it and the W/M comes on my A/F drops down into the 10.2-11.2 range!!!! THAT IS LEAN! This can not be good for my engine. I am almost thinking about taking it all out of the car so i don't blow something up! Should I be worried about this? I need your opinions.
Josh
Josh
The w/m is injecting in the bi-pipes. One on each side. The A/F is getting a reading from the wideband O2 that is installed in the exhaust system.
Josh
Josh
yeah everyone I know has to get a tune once they get the w/m kit or jsut a mister here is link for a mister and what he did after the install.
http://www.audiworld.com/tech/eng80b.shtml
ORIGINAL: ThePaintballGuy
Josh
Josh
You should, as said before timing and boost should be adjusted to get the best results.
You aren't misfiring or pre-igniting are you?
