S4 Misfire Help
Old Aug 13, 2008 | 09:52 PM
Jaded S4's Avatar
Default S4 Misfire Help
Hey Guys,
So I'm getting a bad misfire while the car is idle. It runs fine otherwise. Here are the DTCs that came up:
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-00 - -
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16690 - Cylinder 6 Misfire Detected
P0306 - 35-00 - -
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
So far I've tried to change the spark plugs, swap ICMs and move coil packs around. Doesn't seem to be any of those. I'm kinda stumped at the moment. Any idea's or input?
Thanks in advance.
Old Aug 14, 2008 | 11:03 AM
readimag's Avatar
your o2's or going out, that is your problem vast has them for 225 for a pair.
Old Aug 17, 2008 | 06:05 AM
RobertMac's Avatar
your o2 sensors and one of your cam shaft adjusters....thats why your getting those cylinder misfires...the job is expensive the 2nd cam adjuster cost 500-700 and the labor can cost you any way from 800-2000. so your looking at a big job. os sensors cost about 200 each labor on that isnt too pricey!!
hope this helps
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
