S4 with no boost at all
Old May 17, 2007 | 03:57 PM
610ish's Avatar
Default S4 with no boost at all
have just bought an 1993 S4 but it has no boost at all the gauge on the dash sits at 0.5 at idle then goes to 1 when driven hard.
have checked
air flow meter
all the hoses
waste gate inc spring
and have just removed plug on exhaust pipe and fitted a gauge on it to measure back pressure in exhaust and getting about 20 psi at 4000rpm
don't know alot about these and don't have the bit of kit to read the fault codes
anyideas or tests i can do?
Old May 17, 2007 | 07:57 PM
fixn2xlr8's Avatar
Default RE: S4 with no boost at all
You either have a big *** boost leak or I have no clue. Wastegates perhaps?
Old May 17, 2007 | 11:59 PM
Woodhead2k's Avatar
Check the line from the gauge to where its taped on the manif? Might just be its kinked or just a bad gauge.
When you're driving and you feel the turbo pull at all?
Old May 18, 2007 | 11:44 AM
S obsessed's Avatar
20 psi of backpressure in exhaustis way too much, You should explain exactly where you tapped in and how. With that much back pressure the vehicle should barely run or not run at all.
Old May 18, 2007 | 04:41 PM
610ish's Avatar
can't turbo kick in at all
am testing the pressure in the exhaust at the small bit of pipe on the down pipe just after the turbo which has a blanking cap over it i guessed this was the test point? and just put a pressure gauge onto this point
Old May 18, 2007 | 06:50 PM
S obsessed's Avatar
Usually it is easy to just pull the oxygen sensor and hook tester there but that spot could very well be a test point and since it should be in a good spot then you should really not have that much pressure. general rule of thumb is no more than 2.5 psi at 2500 rpm and generally no more than 6 psi at full load. your cat could be plugged in some way. Unhook from catalytic convertor back and try again. If you have that much back pressure your turbo won't want to spin since it is the expanding of gasses from the high pressure to low pressure that spins it.
Old May 19, 2007 | 04:33 PM
610ish's Avatar
all fixed now thanks all!
took cats off and banged the guts out and now i get boost![sm=burnout.gif]
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
