Sequential Turbo S4
i think that is how set up on Porsches is. sequential. one runs low RPM. other one for high. i would immagine K03 is better for low RPMs cause of lighter weight it will spool up faster, with practically no turbo lag. then K04 would kick in at about 3500-4000 RPM.
i think the last Mazda RX-7 did same thing. Nissan 300Z and Toyota Supra and Mitsubishi 3000GT went twin turbo like Audi, one for a set of banks. But you have to remember that those cars are V6 engines, while Porsche is a Boxter engine and RX-7 is rotor. the whole set up is different. I heard some people on Porsche were switching the K03 for a second K04 to get more horses. but those are the people who do tracking and stuff....
doing sequential for Audi probably possible, but considering the setup - it will be more expensive then simply switching the tubos for K04. people with A4 may do that, cause they start from the scratch. S4 is pre-wired for 2 turbos - do not see the need for redoing the whole setup. i doubt u can get more out of the engine that way.
well, in the sequential turbo u r running one turbo at any given time... so lets say at 5,000 RPM only the larger of two spins and provides boost. in Audi setup u will have two K04 turbos running full boost at same RPM. i would suspect the Torgue on Audi will be a lot bigger then on sequential setup.
ORIGINAL: alex verve
I'm in agreement with your points (later posts)... the S4 arrangement is plumbed for the turbos to run together. Sequential, in concept, is a great idea, but it would require re-engineering the entire sytem to accomodated the S4 V6.
