snub mount=amazing but found a different problem
Old Apr 17, 2009 | 11:53 PM
bottlecap's Avatar
Default snub mount=amazing but found a different problem
i installed my snub mount today thats been sittin around my dining room for the past 2 months. omg why did i wait so long to do it!! its the best thing ever!! my shifts are sooo much smoother now! i was on the verge of thinkin my tranny needed a rebuild but no..just a 30 dollar part and a free afternoon.
bad news tho...okay so some may remember i just got both turbos replaced back in january. ever since i've been lettin them warm up and cool down like you're supposed to before boosting, bear in mind these are brand new not rebuilt turbos...so the past few days i've noticed a little extra whiteness in my exhaust and what do you ******* know, i pull both my lower intercooler lines off since i had the bumper off and a little trickle of oil came out each of them. what the ****!?! the turbos dont sound dentist drill at all like they used to and im still boosting 100% on stock no chip..what could it be?!
ps the snub mount made me so happy im not to terribley angry about the turbos!
Old Apr 18, 2009 | 09:38 AM
CamoA6's Avatar
did the shop just not clean out the old oil? they COULD just be burning off the old oil. I donno. just a though. Go see your mechanic and get to the bottom of it.
Old Apr 18, 2009 | 01:24 PM
bottlecap's Avatar
i will, they're closed on the weekends so its going to have to wait, i was thinking that because when i popped the passenger side one off it had yellow dye in it like that they use to find oil leaks with a black light. buttt they said they flushed out my intercoolers to clean them when they replaced the turbos and you'd think they'd drain the oil out of the lines too..
Old Apr 19, 2009 | 12:10 PM
a12gaugehug's Avatar
how hard was the snub mount to do?
everytime i shift it feels like the motors going to go through the front of the car. could be motor mounts as well i suppose.
Old Apr 19, 2009 | 01:31 PM
bottlecap's Avatar
it took me about an hour and two beers. the hardest part is getting the mount off the spindle but a fork tool really helps if you get one wide enough to fit around it. then just lube up the new mount on the inside and around the spindle. i just used some high heat silicone lube and it popped on pretty easy with a little effort. i had a buddy help hold the radiator up for me tho as i was working and that cost another beer. now the only problem with the reinstall was trying to get my passenger side of the bumper to fit correctly..it keeps popping out of its mount
Old Apr 20, 2009 | 12:15 AM
LowA4's Avatar
If you stick the snub in the microwave for about 30 seconds to soften it up, that helps slide it on too.
Old Apr 20, 2009 | 12:51 AM
bottlecap's Avatar
microwave eh? never thought of that. A12 try the snub mount before you do replace your motor mounts..it could be that simple of a fix and you dont need to pull the motor
Old Apr 20, 2009 | 07:27 AM
ill do that when i have the front apart doing the p/s pump
tylertitus14
Nov 10, 2011 02:07 AM
Tanker
B7 Models
Jun 4, 2009 02:31 PM
milo55041
Oct 24, 2007 02:42 PM
EliteTuning1
Nov 18, 2006 01:24 PM
mjvss21
Feb 22, 2006 07:03 PM
