stick shift moving
Old Jun 4, 2008 | 11:47 AM
rpriske's Avatar
Default stick shift moving
Hey,does anyone know what is causing this?When I'm driving, the stick shift bumps back and forth. It seems to happen when letting off the gas and back on.
Old Jun 4, 2008 | 01:18 PM
jonnyblazz1's Avatar
Default RE: stick shift moving
Thats normal. Maby not the amount of movement your getting. Transmission mount should be checked along with motor mounts.
Old Jun 4, 2008 | 08:59 PM
readimag's Avatar
yeah that is way normal for our cars you get a TSB from awe and it clears right up.
Old Jun 5, 2008 | 08:53 AM
Blue Jay's Avatar
What is causing it is that the shifter in bolted to the transmission, so when the drivetrain moves, the shifter moves with it. Pretty common in High performance cars.
Old Jun 5, 2008 | 10:50 AM
CamoA6's Avatar
My A6 2.7 does it. but my S4 does not but it has a UUC short shifter. I donno if thats why
Old Jun 5, 2008 | 10:56 AM
meatbiscuit's Avatar
Didn't think about that, the short shifter doesn't move like the stock shifter? Is it not moving at all or is it just very slight since the throw is shorter?
Old Jun 5, 2008 | 11:21 AM
CamoA6's Avatar
No in the S my shifter doesn't move at all. I will double check it on the way home (im at school now) and I'll let you know after I double check. I'm pretty sure it is solid though.
Old Jun 5, 2008 | 01:20 PM
CamoA6's Avatar
So I just checked on my ride home and it doesn't move at all. I even tried by feel and felt nothing.
Old Jun 5, 2008 | 01:40 PM
readimag's Avatar
your lucky then, mine moved then i got on the gas and off of it all the time till i got a dts by awe.
Old Jun 5, 2008 | 01:41 PM
That's pretty cool. Short shifter must just be more stable or something, I didn't expect that. Thx for the follow-up
