Stock boost is?
Old Jul 12, 2007 | 01:32 PM
2000S4's Avatar
Default Stock boost is?
What is stock boost on the B5 S4? PSI wise
Old Jul 12, 2007 | 01:40 PM
Brandon2000s4's Avatar
Default RE: Stock boost is?
Mine is around 12.2 psi stock.
Old Jul 12, 2007 | 06:06 PM
SilverAudiS4's Avatar
What is the maximum boost these motors can run with stock fuel?
Old Jul 12, 2007 | 08:35 PM
2k S4's Avatar
Stock is 10psi.
With the K03's it's not fuel but the turbo's that give up. You don't really get any more CFM pushing them at much over 19psi.
Old Jul 13, 2007 | 02:32 AM
Stuckeyman87's Avatar
the apr 93 octane chip runs 14.5 psi and the giac chip runs 17 psi, correct?
Old Jul 13, 2007 | 07:16 AM
Side question? How many wastgates are on these cars? Is it just one for each turbo? Or is there a third that is making sure there is not too much boost coming from the two combined turbos?
Old Jul 13, 2007 | 12:30 PM
GeilKyle2's Avatar
There is 2 wastegates, one for each turbo
Old Jul 13, 2007 | 03:07 PM
So if stock psi is 10 then each one is set at? 5? Is there anyway to change this on the wastegate without a boost controler?
Old Jul 13, 2007 | 10:28 PM
2k S4's Avatar
ORIGINAL: SilverAudiS4
It doesn't add up, they both put out the same PSI. The reason for 2 is to increase CFM.
No matter what you do, the N75 will cut the boost to what the ECU request.
Old Jul 14, 2007 | 01:16 AM
oh okay, that makes sense, i figured it just added up from both turbos. is there anyway to trick the car to add more boost? or would that require a fuel controler as well...?
